Ga door naar hoofdinhoud
iView-776TPCII Wi-Fi Antenna Replacement
Wat je nodig hebt
  1. iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: stap 1, afbeelding 1 van 3 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: stap 1, afbeelding 2 van 3 iView-776TPCII Wi-Fi Antenna Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
    Vraag FixBot
    Voeg opmerking toe
  2. iView-776TPCII Wi-Fi Antenna Replacement: stap 2, afbeelding 1 van 2 iView-776TPCII Wi-Fi Antenna Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
    Vraag FixBot
    Voeg opmerking toe
  3. iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 3, afbeelding 1 van 2 iView-776TPCII Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 3, afbeelding 2 van 2
    • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
    Vraag FixBot
    Voeg opmerking toe
  4. iView-776TPCII Wi-Fi Antenna Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wire free from its connection.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Cory Gratzer
586 Reputatie
5 handleidingen geschreven
IUPUI, Team 2-2, Baechle Fall 2015 Lid van IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 28
Altijd: 710
