Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Follow the steps in this guide to replace the earpiece speaker in your iPhone 6s Plus.
You can also use this guide to replace the earpiece speaker bracket.
  1. Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  5. The safest place to pry from is the notch in the front panel above the headphone jack. While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack. While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  6. Twist the spudger to widen the gap between the front panel and the rear case. Twist the spudger to widen the gap between the front panel and the rear case.
    • Twist the spudger to widen the gap between the front panel and the rear case.
  7. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  8. Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case. Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  9. Insert the flat tip of the spudger under the right edge of the display. Slide the spudger up the right side.
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  10. Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone. Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  11. Pull up on the small nub on the suction cup to remove it from the display. Pull up on the small nub on the suction cup to remove it from the display.
    • Pull up on the small nub on the suction cup to remove it from the display.
  12. Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge. Open the display to about a 90Āŗ angle, and lean it against something to keep it propped up while you're working on the phone. Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90Āŗ angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  13. Remove the battery connector bracket. Remove the battery connector bracket.
    • Remove the battery connector bracket.
  14. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  15. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  16. Remove the following Phillips screws:
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  17. Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  18. Be careful to only pry up on the connector itself and not the socket on the logic board. Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  19. Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  20. Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  21. Remove the display assembly. During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
  22. Remove the following three Phillips screws:
    • Remove the following three Phillips screws:
    • Two 2.7 mm screws
    • One 1.4 mm screw
  23. Remove the earpiece speaker bracket. Remove the earpiece speaker bracket.
    • Remove the earpiece speaker bracket.
  24. Use the flat end of a spudger to lift the FaceTime camera out of its housing. Use the flat end of a spudger to lift the FaceTime camera out of its housing.
    • Use the flat end of a spudger to lift the FaceTime camera out of its housing.
  25. Pull the FaceTime camera back and remove the earpiece speaker. Pull the FaceTime camera back and remove the earpiece speaker.
    • Pull the FaceTime camera back and remove the earpiece speaker.
Conclusie
75 andere personen hebben deze handleiding voltooid.
Evan Noronha
202.176 Reputatie
178 handleidingen geschreven
iFixit Lid van iFixit
Community
135 Leden
13.899 handleidingen geschreven
Is there really a difference between 6s and 6s plus ear speaker?
AWT - Antwoord
For future reference, I found only a slight physical difference between the two. Tested both out on a 6s Plus and they both seem to work exactly the same.
Corey Hawkins -
Awsome done it
Sangam chauhan - Antwoord
Guide worked well. Fixed my 6s Plus with no issues.
Thanks.
jim crusan - Antwoord
Is the earpiece bracket the same as the one in the iphone 6s?
adam Meaney - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 81
Afgelopen 30 dagen: 375
Altijd: 39,374
