Ga door naar hoofdinhoud
iPhone 6 Power Button Cable Assembly Replacement
Wat je nodig hebt
  1. iPhone 6 Power Button Cable Assembly Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
    Vraag FixBot
    Voeg opmerking toe
  2. iPhone 6 Power Button Cable Assembly Replacement, Anti-Clamp instructions: stap 2, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement, Anti-Clamp instructions: stap 2, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement, Anti-Clamp instructions: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Vraag FixBot
    Voeg opmerking toe
  3. iPhone 6 Power Button Cable Assembly Replacement: stap 3, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 3, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 3, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Vraag FixBot
    Voeg opmerking toe
  4. iPhone 6 Power Button Cable Assembly Replacement, Manual Opening Procedure: stap 4, afbeelding 1 van 1
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Vraag FixBot
    Voeg opmerking toe
  5. iPhone 6 Power Button Cable Assembly Replacement: stap 5, afbeelding 1 van 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    Vraag FixBot
    Voeg opmerking toe
  6. iPhone 6 Power Button Cable Assembly Replacement: stap 6, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 6, afbeelding 2 van 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    Vraag FixBot
    Voeg opmerking toe
  7. iPhone 6 Power Button Cable Assembly Replacement, Opening up the phone: stap 7, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement, Opening up the phone: stap 7, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement, Opening up the phone: stap 7, afbeelding 3 van 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
    Vraag FixBot
    Voeg opmerking toe
  8. iPhone 6 Power Button Cable Assembly Replacement: stap 8, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 8, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 8, afbeelding 3 van 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    Vraag FixBot
    Voeg opmerking toe
  9. iPhone 6 Power Button Cable Assembly Replacement, Removing the battery connector bracket screws: stap 9, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
    Vraag FixBot
    Voeg opmerking toe
  10. iPhone 6 Power Button Cable Assembly Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  11. iPhone 6 Power Button Cable Assembly Replacement, Disconnecting the battery connector: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
    Vraag FixBot
    Voeg opmerking toe
  12. iPhone 6 Power Button Cable Assembly Replacement, Removing the front panel assembly cable bracket screws: stap 12, afbeelding 1 van 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
    Vraag FixBot
    Voeg opmerking toe
  13. iPhone 6 Power Button Cable Assembly Replacement: stap 13, afbeelding 1 van 1
    • Remove the front panel assembly cable bracket from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  14. iPhone 6 Power Button Cable Assembly Replacement: stap 14, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 14, afbeelding 2 van 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
    Vraag FixBot
    Voeg opmerking toe
  15. iPhone 6 Power Button Cable Assembly Replacement: stap 15, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 15, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
    Vraag FixBot
    Voeg opmerking toe
  16. iPhone 6 Power Button Cable Assembly Replacement: stap 16, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 16, afbeelding 2 van 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  17. iPhone 6 Power Button Cable Assembly Replacement: stap 17, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 17, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    Vraag FixBot
    Voeg opmerking toe
  18. iPhone 6 Power Button Cable Assembly Replacement, Separating front panel assembly and rear case: stap 18, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  19. iPhone 6 Power Button Cable Assembly Replacement, SIM Card: stap 19, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement, SIM Card: stap 19, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
    Vraag FixBot
    Voeg opmerking toe
  20. iPhone 6 Power Button Cable Assembly Replacement: stap 20, afbeelding 1 van 1
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Vraag FixBot
    Voeg opmerking toe
  21. iPhone 6 Power Button Cable Assembly Replacement, Logic Board: stap 21, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement, Logic Board: stap 21, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
    Vraag FixBot
    Voeg opmerking toe
  22. iPhone 6 Power Button Cable Assembly Replacement: stap 22, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 22, afbeelding 2 van 2
    • Use the point of a spudger to lift the antenna cable connector up off of its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  23. iPhone 6 Power Button Cable Assembly Replacement: stap 23, afbeelding 1 van 1
    • Remove the following Phillips screws from the upper cable bracket:
    • One 2.9 mm screw
    • One 2.2 mm screw
    Vraag FixBot
    Voeg opmerking toe
  24. iPhone 6 Power Button Cable Assembly Replacement: stap 24, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 24, afbeelding 2 van 2
    • Remove the upper cable bracket from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  25. iPhone 6 Power Button Cable Assembly Replacement: stap 25, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 25, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 25, afbeelding 3 van 3
    • When disconnecting the following connectors, only pry up on the connector, not the socket on the logic board or you risk permanent damage.
    • Use the flat end of a spudger to lift the power button and flash assembly cable connector up off of its socket.
    • Lift the volume control cable connector up out of its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  26. iPhone 6 Power Button Cable Assembly Replacement: stap 26, afbeelding 1 van 1
    • Remove the following four Phillips screws from the Wi-Fi antenna:
    • One 1.5 mm screw
    • One 1.4 mm screw
    • Two 2.1 mm screws
    Vraag FixBot
    Voeg opmerking toe
  27. iPhone 6 Power Button Cable Assembly Replacement: stap 27, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 27, afbeelding 2 van 2
    • Remove the Wi-Fi antenna from the iPhone.
    • Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
    Vraag FixBot
    Voeg opmerking toe
  28. iPhone 6 Power Button Cable Assembly Replacement: stap 28, afbeelding 1 van 1
    • Remove the two 1.6 mm Phillips screws from the grounding bracket.
    Vraag FixBot
    Voeg opmerking toe
  29. iPhone 6 Power Button Cable Assembly Replacement: stap 29, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 29, afbeelding 2 van 2
    • Remove the grounding bracket from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  30. iPhone 6 Power Button Cable Assembly Replacement: stap 30, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 30, afbeelding 2 van 2
    • Remove the following Phillips screws securing the angled logic board bracket.
    • One 2.6 mm screw
    • One 1.3 mm screw, located horizontally in the upper sidewall of the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  31. iPhone 6 Power Button Cable Assembly Replacement: stap 31, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 31, afbeelding 2 van 2
    • Remove the angled logic board bracket.
    Vraag FixBot
    Voeg opmerking toe
  32. iPhone 6 Power Button Cable Assembly Replacement: stap 32, afbeelding 1 van 1
    • Remove the single 1.2 mm Phillips screw securing the antenna interconnect cable to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  33. iPhone 6 Power Button Cable Assembly Replacement: stap 33, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 33, afbeelding 2 van 2
    • Use the point of a spudger to fold the antenna interconnect cable up out of the way of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  34. iPhone 6 Power Button Cable Assembly Replacement: stap 34, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 34, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 34, afbeelding 3 van 3
    • Use the flat end of a spudger to lift the camera cable connector straight up out of its socket on the logic board.
    • Be sure to only pry on the connector not the socket itself or you can cause permanent damage to the logic board.
    • Fold the camera cable up out of the way of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  35. iPhone 6 Power Button Cable Assembly Replacement: stap 35, afbeelding 1 van 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 1.9 mm Phillips screws
    • One 2.3 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Vraag FixBot
    Voeg opmerking toe
  36. iPhone 6 Power Button Cable Assembly Replacement: stap 36, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 36, afbeelding 2 van 2
    • Use the flat end of a spudger to lift the battery connector end of the logic board up slightly, just enough to grab with your fingers.
    • Insert the spudger near the metal shields below the SIM card tray to avoid damaging any chips or sockets.
    Vraag FixBot
    Voeg opmerking toe
  37. iPhone 6 Power Button Cable Assembly Replacement: stap 37, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 37, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 37, afbeelding 3 van 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Vraag FixBot
    Voeg opmerking toe
  38. iPhone 6 Power Button Cable Assembly Replacement, Power Button Cable Assembly: stap 38, afbeelding 1 van 1
    • Peel back the first battery adhesive tab from the bottom right edge of the battery.
    • Use your fingers or blunt tweezers, and be extra careful when working near the battery—puncturing a lithium-ion battery can release dangerous chemicals and cause a fire.
    Vraag FixBot
    Voeg opmerking toe
  39. iPhone 6 Power Button Cable Assembly Replacement: stap 39, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 39, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 39, afbeelding 3 van 3
    • Gently pull the battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Try not to pull against the battery or the lower components, or you may rip the adhesive strip.
    • Continue pulling, allowing the strip to slowly slip out from between the battery and the rear case. When you feel increased resistance from the strip, stop pulling and continue with the next step.
    • If the battery adhesive tabs break off at any point during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then proceed to Step 44.
    Vraag FixBot
    Voeg opmerking toe
  40. iPhone 6 Power Button Cable Assembly Replacement: stap 40, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 40, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 40, afbeelding 3 van 3
    • When you feel increased resistance from the adhesive strip, pull it gently around the lower right corner of the battery.
    • Continue pulling the adhesive tab upward and away from the right edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
    • Don't allow the adhesive strip to snag on the battery connector, or it may tear or break off.
    Vraag FixBot
    Voeg opmerking toe
  41. iPhone 6 Power Button Cable Assembly Replacement: stap 41, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 41, afbeelding 2 van 2
    • Peel back the second battery adhesive tab from the bottom left edge of the battery.
    • Again, gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
    • Continue pulling the adhesive tab until you feel increased resistance, and then stop.
    Vraag FixBot
    Voeg opmerking toe
  42. iPhone 6 Power Button Cable Assembly Replacement: stap 42, afbeelding 1 van 1
    • When you feel increased resistance from the adhesive strip, pull it gently around the lower left corner of the battery.
    • Don't allow the adhesive strip to snag on the corner of the battery, or it may tear or break off.
    • Continue pulling the adhesive tab upward and away from the left edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
    • If you removed both adhesive strips successfully, skip the next two steps and continue on Step 46.
    • If either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
    Vraag FixBot
    Voeg opmerking toe
  43. iPhone 6 Power Button Cable Assembly Replacement: stap 43, afbeelding 1 van 1
    • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
    Vraag FixBot
    Voeg opmerking toe
  44. iPhone 6 Power Button Cable Assembly Replacement: stap 44, afbeelding 1 van 1
    Plastic Cards
    $2.99
    • Insert a plastic card under the logic board edge of the battery.
    • Be careful to keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
    • Press the card in at several points if necessary to break up the adhesive behind the battery.
    Vraag FixBot
    Voeg opmerking toe
  45. iPhone 6 Power Button Cable Assembly Replacement: stap 45, afbeelding 1 van 1
    • After peeling or prying out all adhesive, remove the battery from the iPhone.
    • When reinstalling the battery, refer to this guide to replace your battery's adhesive strips.
    Vraag FixBot
    Voeg opmerking toe
  46. iPhone 6 Power Button Cable Assembly Replacement: stap 46, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 46, afbeelding 2 van 2
    • Remove any tape covering the upper left rear-facing camera screw.
    Vraag FixBot
    Voeg opmerking toe
  47. iPhone 6 Power Button Cable Assembly Replacement: stap 47, afbeelding 1 van 1
    • Remove the following Phillips #00 screws from the rear-facing camera bracket:
    • One 1.5 mm screw
    • One 2.1 mm screw
    Vraag FixBot
    Voeg opmerking toe
  48. iPhone 6 Power Button Cable Assembly Replacement: stap 48, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 48, afbeelding 2 van 2
    • Remove the rear-facing camera bracket.
    Vraag FixBot
    Voeg opmerking toe
  49. iPhone 6 Power Button Cable Assembly Replacement: stap 49, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 49, afbeelding 2 van 2
    • Carefully remove the antenna interconnect cable from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  50. iPhone 6 Power Button Cable Assembly Replacement: stap 50, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 50, afbeelding 2 van 2
    • Remove the rear-facing camera from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  51. iPhone 6 Power Button Cable Assembly Replacement: stap 51, afbeelding 1 van 1
    • Remove the single 1.2 mm Phillips #00 screw securing the flash bracket.
    Vraag FixBot
    Voeg opmerking toe
  52. iPhone 6 Power Button Cable Assembly Replacement: stap 52, afbeelding 1 van 2 iPhone 6 Power Button Cable Assembly Replacement: stap 52, afbeelding 2 van 2
    • Remove the flash bracket from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  53. iPhone 6 Power Button Cable Assembly Replacement: stap 53, afbeelding 1 van 1
    • Remove the two 2.2 mm Phillips #00 screws from the power button bracket.
    Vraag FixBot
    Voeg opmerking toe
  54. iPhone 6 Power Button Cable Assembly Replacement: stap 54, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 54, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 54, afbeelding 3 van 3
    • Use the point of a spudger to gently push the flash and microphone modules up out of their respective holes in the rear case.
    • If you encounter significant adhesive, use tweezers to peel the components up from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  55. iPhone 6 Power Button Cable Assembly Replacement: stap 55, afbeelding 1 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 55, afbeelding 2 van 3 iPhone 6 Power Button Cable Assembly Replacement: stap 55, afbeelding 3 van 3
    • Begin to peel the flash/microphone/power button assembly cable up from the rear case starting from the connector end.
    • Continue to peel the cable up, being particularly careful of the narrow component ends of the cable.
    • Remove the flash/microphone/power button assembly cable from the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
85 andere personen hebben deze handleiding voltooid.
Sam Goldheart
477.667 Reputatie
538 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
27.557 handleidingen geschreven
11Gids Commentaar
Thanks! This is helpful!
Luke L - Antwoord Deel
This helped out a lot, couldn't find a good enough photo on how the power button was put back on its mount.
alexkasper16 - Antwoord Deel
Took me 2.5 hours to complete this. Had a hard time getting the factory cable connector off the power button. Used some 3M Double Sided Adhesive tape- 2mm width, Black color to hold the new replacement cable connector in place on the power button. An IFIXIT video showing how to install the connector onto the power switch would be a big help. Had to use a You-Tube video to complete that step. Also, a good reminder to ensure all your connector cables are clear when reinstalling the logic board. You definitely don't want to pinch any of them. Follow the directions carefully and patience is a must! Wasn't that hard for my first time replacing this flex cable.
ronjon40 - Antwoord Deel
PRO TIP Order a part that already has the metal bracket attached for a few cents more and save yourself the hassle. I buy all my parts on eBay because of their awesome buyer protection and sellers always want to keep a good rating.
ForumHermit - Antwoord Deel
I think I got a broken cable. Can someone help me with that?
It looks like this: https://drive.google.com/drive/folders/1...
Is it broken and can I fix it? Or is this normal and what to do?
Katrin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 99
Altijd: 88,625
