Ga door naar hoofdinhoud
iPhone 5c Logic Board Replacement
Wat je nodig hebt
Video overzicht
  1. iPhone 5c Logic Board Replacement, Taping the display glass: stap 1, afbeelding 1 van 3 iPhone 5c Logic Board Replacement, Taping the display glass: stap 1, afbeelding 2 van 3 iPhone 5c Logic Board Replacement, Taping the display glass: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Vraag FixBot
    Voeg opmerking toe
  2. iPhone 5c Logic Board Replacement, Removing the Pentalobe screws: stap 2, afbeelding 1 van 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
    Vraag FixBot
    Voeg opmerking toe
  3. iPhone 5c Logic Board Replacement, Starting the iSclack Opening Procedure: stap 3, afbeelding 1 van 3 iPhone 5c Logic Board Replacement, Starting the iSclack Opening Procedure: stap 3, afbeelding 2 van 3 iPhone 5c Logic Board Replacement, Starting the iSclack Opening Procedure: stap 3, afbeelding 3 van 3
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  4. iPhone 5c Logic Board Replacement, Finishing the iSclack Opening Procedure: stap 4, afbeelding 1 van 2 iPhone 5c Logic Board Replacement, Finishing the iSclack Opening Procedure: stap 4, afbeelding 2 van 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 8.
    Vraag FixBot
    Voeg opmerking toe
  5. iPhone 5c Logic Board Replacement, Manual Opening Procedure: stap 5, afbeelding 1 van 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    Vraag FixBot
    Voeg opmerking toe
  6. iPhone 5c Logic Board Replacement, Start lifting the front panel assembly: stap 6, afbeelding 1 van 2 iPhone 5c Logic Board Replacement, Start lifting the front panel assembly: stap 6, afbeelding 2 van 2
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    Vraag FixBot
    Voeg opmerking toe
  7. iPhone 5c Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
    Vraag FixBot
    Voeg opmerking toe
  8. iPhone 5c Logic Board Replacement, Opening up the phone: stap 8, afbeelding 1 van 2 iPhone 5c Logic Board Replacement, Opening up the phone: stap 8, afbeelding 2 van 2
    • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    Vraag FixBot
    Voeg opmerking toe
  9. iPhone 5c Logic Board Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  10. iPhone 5c Logic Board Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  11. iPhone 5c Logic Board Replacement, Disconnecting the battery connector: stap 11, afbeelding 1 van 1
    • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    Vraag FixBot
    Voeg opmerking toe
  12. iPhone 5c Logic Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.3 mm screws
    • One 1.7 mm screw
    • One 3.25 mm screw
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
    Vraag FixBot
    Voeg opmerking toe
  13. iPhone 5c Logic Board Replacement: stap 13, afbeelding 1 van 1
    • Remove the front panel assembly cable bracket from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  14. iPhone 5c Logic Board Replacement, Disconnecting the front panel assembly cables: stap 14, afbeelding 1 van 2 iPhone 5c Logic Board Replacement, Disconnecting the front panel assembly cables: stap 14, afbeelding 2 van 2
    • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
    • Be sure to only pry up on the connector, and not on the socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  15. iPhone 5c Logic Board Replacement: stap 15, afbeelding 1 van 3 iPhone 5c Logic Board Replacement: stap 15, afbeelding 2 van 3 iPhone 5c Logic Board Replacement: stap 15, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
    • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
    • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    Vraag FixBot
    Voeg opmerking toe
  16. iPhone 5c Logic Board Replacement, Separating front panel assembly and rear case: stap 16, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  17. iPhone 5c Logic Board Replacement, SIM Card: stap 17, afbeelding 1 van 2 iPhone 5c Logic Board Replacement, SIM Card: stap 17, afbeelding 2 van 2
    • Shut your phone down completely before removing the SIM card and tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press the SIM card eject tool inwards to eject the tray.
    • This may require a significant amount of force.
    Vraag FixBot
    Voeg opmerking toe
  18. iPhone 5c Logic Board Replacement: stap 18, afbeelding 1 van 1
    • Remove the SIM Card tray assembly from the iPhone.
    • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
    Vraag FixBot
    Voeg opmerking toe
  19. iPhone 5c Logic Board Replacement, Logic Board: stap 19, afbeelding 1 van 1
    • Disconnect the Lightning connector ribbon cable from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  20. iPhone 5c Logic Board Replacement: stap 20, afbeelding 1 van 3 iPhone 5c Logic Board Replacement: stap 20, afbeelding 2 van 3 iPhone 5c Logic Board Replacement: stap 20, afbeelding 3 van 3
    • The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
    Vraag FixBot
    Voeg opmerking toe
  21. iPhone 5c Logic Board Replacement: stap 21, afbeelding 1 van 2 iPhone 5c Logic Board Replacement: stap 21, afbeelding 2 van 2
    • Fold the cable up out of the way of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  22. iPhone 5c Logic Board Replacement: stap 22, afbeelding 1 van 1
    • Disconnect the antenna connector from the base of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  23. iPhone 5c Logic Board Replacement: stap 23, afbeelding 1 van 1
    • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  24. iPhone 5c Logic Board Replacement: stap 24, afbeelding 1 van 1
    • Disconnect the rear facing camera cable connector from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  25. iPhone 5c Logic Board Replacement: stap 25, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
    Vraag FixBot
    Voeg opmerking toe
  26. iPhone 5c Logic Board Replacement: stap 26, afbeelding 1 van 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Three 2.7 mm standoff screws
    • Standoff screws are best removed with a standoff screwdriver or standoff driver bit. A small flathead screwdriver can also do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 2.5 mm Phillips #000 screw
    Vraag FixBot
    Voeg opmerking toe
  27. iPhone 5c Logic Board Replacement: stap 27, afbeelding 1 van 2 iPhone 5c Logic Board Replacement: stap 27, afbeelding 2 van 2
    • Remove the 1.2 mm Phillips #000 screw securing the grounding clip to the top side-wall.
    • Use tweezers to remove the logic board grounding clip.
    Vraag FixBot
    Voeg opmerking toe
  28. iPhone 5c Logic Board Replacement: stap 28, afbeelding 1 van 1
    • Use a plastic opening tool to gently lift the lower end of the logic board up from the rear case enough for you to grab it with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  29. iPhone 5c Logic Board Replacement: stap 29, afbeelding 1 van 3 iPhone 5c Logic Board Replacement: stap 29, afbeelding 2 van 3 iPhone 5c Logic Board Replacement: stap 29, afbeelding 3 van 3
    • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
    • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  30. iPhone 5c Logic Board Replacement: stap 30, afbeelding 1 van 2 iPhone 5c Logic Board Replacement: stap 30, afbeelding 2 van 2
    • Flip the logic board up toward the volume control buttons to expose the antenna connector.
    • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
    Vraag FixBot
    Voeg opmerking toe
  31. iPhone 5c Logic Board Replacement: stap 31, afbeelding 1 van 1
    • Disconnect the antenna connector from the back of the logic board.
    • There may be glue holding the connector in place.
    Vraag FixBot
    Voeg opmerking toe
  32. iPhone 5c Logic Board Replacement: stap 32, afbeelding 1 van 1
    • Remove the logic board from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
146 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
515.368 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
31.531 handleidingen geschreven
14Gids Commentaar
Would a logic board swap be easier than a battery swap between 2 iPhone 5C's? ?
Dylan Tran - Antwoord Deel
A battery swap would be significantly easier! Here's the battery replacement guide. =)
Sam Goldheart - Antwoord Deel
While I was repairing my phone, I guess the part where I didn't go around was taking out the battery because it felt like it was the more fragile part. This was because I did not have the proper equipment to take it away. This guide was pretty helpful for me in reconnecting cables.
Anyway, I am bothered that as I took out the logic board, there was this golden thing that just slid out of place. It slid from the top portion of the phone, but I do not know where it was originally and I do not know how it was supposed to be placed. It looked like an open box of sorts (but only had 3 sides bent up) and had a hole in the middle. It would be great if anyone would know where it could be placed so I could put back my phone.
Fimbo Gaming - Antwoord Deel
Look at step 29 :)
Gigabit87898 - Antwoord Deel
Where i can buy this board for iphone5c
sami ullah - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 147
Altijd: 116,076
