Ga door naar hoofdinhoud
iHome iP1 Motherboard Replacement
Wat je nodig hebt
    1. iHome iP1 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Orient the iHome upside down with the speakers facing away from you.
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iP1 Motherboard Replacement: stap 2, afbeelding 1 van 2 iHome iP1 Motherboard Replacement: stap 2, afbeelding 2 van 2
      • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome iP1 Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Remove the back cover by grabbing its sides and lifting it off the iHome.
      Vraag FixBot
      Voeg opmerking toe
    1. iHome iP1 Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 iHome iP1 Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
      • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
      • The order in which the wire bundles are removed does not matter.
      • You may need to remove some black foam tape in order fully disconnect some of the wires.
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iP1 Motherboard Replacement: stap 5, afbeelding 1 van 2 iHome iP1 Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome iP1 Motherboard Replacement: stap 6, afbeelding 1 van 2 iHome iP1 Motherboard Replacement: stap 6, afbeelding 2 van 2
      • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
      Vraag FixBot
      Voeg opmerking toe
    4. iHome iP1 Motherboard Replacement: stap 7, afbeelding 1 van 3 iHome iP1 Motherboard Replacement: stap 7, afbeelding 2 van 3 iHome iP1 Motherboard Replacement: stap 7, afbeelding 3 van 3
      • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sachin Shenoi
369 Reputatie
2 handleidingen geschreven
Cal Poly, Team 20-1, Livingston Fall 2016 Lid van Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 Leden
14 handleidingen geschreven
6Gids Commentaar
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - Antwoord Deel
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - Antwoord Deel
Were you able to buy the motherboard?
Rodrigo - Antwoord Deel
Rodrigo
rodrigo@r7criacoes.com.br
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 2,360
