Ga door naar hoofdinhoud
iHome IH11 AC Power Adapter Replacement
Wat je nodig hebt
    1. iHome IH11 AC Power Adapter Replacement, Outer Case: stap 1, afbeelding 1 van 1
      • Unscrew the two 9.0 mm screws with the Phillips #1.
      • Remove the translucent bottom plastic piece.
      Vraag FixBot
      Voeg opmerking toe
    2. iHome IH11 AC Power Adapter Replacement: stap 2, afbeelding 1 van 2 iHome IH11 AC Power Adapter Replacement: stap 2, afbeelding 2 van 2
      • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
      • Repeat the previous step for the two 9.0mm screws on the bottom.
      • Carefully slide the back cover off. There are wires attached to the back cover.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome IH11 AC Power Adapter Replacement: stap 3, afbeelding 1 van 1
      • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
      Vraag FixBot
      Voeg opmerking toe
    4. iHome IH11 AC Power Adapter Replacement, Motherboard: stap 4, afbeelding 1 van 2 iHome IH11 AC Power Adapter Replacement, Motherboard: stap 4, afbeelding 2 van 2
      • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
      • Slide the motherboard gently out.
      Vraag FixBot
      Voeg opmerking toe
    5. iHome IH11 AC Power Adapter Replacement: stap 5, afbeelding 1 van 1
      • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
      • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
      Vraag FixBot
      Voeg opmerking toe
    6. iHome IH11 AC Power Adapter Replacement: stap 6, afbeelding 1 van 2 iHome IH11 AC Power Adapter Replacement: stap 6, afbeelding 2 van 2
      • Unsolder the main connections holding the AC adapter to the circuit board.
      • Solder new adapter in same position with same connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nick Knowles
21 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-9, Maness Spring 2013 Lid van Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 1,024
