Ga door naar hoofdinhoud
dreamGEAR Quad Dock Pro LEDs Replacement
Wat je nodig hebt
    1. dreamGEAR Quad Dock Pro LEDs Replacement, Prerequisite Guide to Accessing Interior: stap 1, afbeelding 1 van 2 dreamGEAR Quad Dock Pro LEDs Replacement, Prerequisite Guide to Accessing Interior: stap 1, afbeelding 2 van 2
      • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. dreamGEAR Quad Dock Pro LEDs Replacement: stap 2, afbeelding 1 van 2 dreamGEAR Quad Dock Pro LEDs Replacement: stap 2, afbeelding 2 van 2
      • Remove the six 2 mm PH0 screws on the bottom of the device.
      • Four of those screws are located under the foot pads.
      Vraag FixBot
      Voeg opmerking toe
    3. dreamGEAR Quad Dock Pro LEDs Replacement: stap 3, afbeelding 1 van 1
      • Gently remove the bottom of the device.
      Vraag FixBot
      Voeg opmerking toe
    1. dreamGEAR Quad Dock Pro LEDs Replacement, Mother Board: stap 4, afbeelding 1 van 2 dreamGEAR Quad Dock Pro LEDs Replacement, Mother Board: stap 4, afbeelding 2 van 2
      • Remove the four 1.8 mm J1 screws.
      • Remove the two 2mm PH0 screws.
      Vraag FixBot
      Voeg opmerking toe
    2. dreamGEAR Quad Dock Pro LEDs Replacement: stap 5, afbeelding 1 van 1
      • Gently pick up the mother board
      • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
      Vraag FixBot
      Voeg opmerking toe
    3. dreamGEAR Quad Dock Pro LEDs Replacement: stap 6, afbeelding 1 van 2 dreamGEAR Quad Dock Pro LEDs Replacement: stap 6, afbeelding 2 van 2
      • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
      Vraag FixBot
      Voeg opmerking toe
    1. dreamGEAR Quad Dock Pro LEDs Replacement, LEDs: stap 7, afbeelding 1 van 2 dreamGEAR Quad Dock Pro LEDs Replacement, LEDs: stap 7, afbeelding 2 van 2
      • Desolder the two points following the instructions included in your soldering kit as you remove the light.
      • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
      • You can follow iFixit's guide to soldering here.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob
757 Reputatie
6 handleidingen geschreven
Colorado Springs, Team 4-4, Panko Spring 2015 Lid van Colorado Springs, Team 4-4, Panko Spring 2015
UCCS-PANKO-S15S4G4
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 484
