Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Remove the tapes one by one from the connecting wires with tweezers.
Remove the black clips from both sides of the casing with a plastic opening tool.
Pull the speakers away from the back casing carefullly.
To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
Using a soldering tool, you will desolder the tabs from the circuit board.
To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
Please refer to Hoe moet je (de-)solderen?
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
will this be the same for a tbqc 1065b?
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
