Ga door naar hoofdinhoud
Zeepad 7DRK Charging Port Replacement
Wat je nodig hebt
    1. Zeepad 7DRK Charging Port  Replacement, Power and Volume Buttons: stap 1, afbeelding 1 van 1
      • First find the power and volume buttons so that you are familiar with their location.
      • The smaller button is the power button and the larger button is the volume button.
      Vraag FixBot
      Voeg opmerking toe
    2. Zeepad 7DRK Charging Port  Replacement: stap 2, afbeelding 1 van 2 Zeepad 7DRK Charging Port  Replacement: stap 2, afbeelding 2 van 2
      • To open the tablet, use one of the soft-tip prying tools.
      • It is easiest to start by using the corner of the tool first and sliding the rest in. Then carefully move the tool around the edges of the tablet until it separates.
      Vraag FixBot
      Voeg opmerking toe
    3. Zeepad 7DRK Charging Port  Replacement: stap 3, afbeelding 1 van 1
      • Be careful of how you open the tablet, as the button will want to fall out. Try opening it flat on its back to avoid this problem.
      • This is what the tablet looks like when pried apart.
      Vraag FixBot
      Voeg opmerking toe
    4. Zeepad 7DRK Charging Port  Replacement: stap 4, afbeelding 1 van 2 Zeepad 7DRK Charging Port  Replacement: stap 4, afbeelding 2 van 2
      • In the first picture you will see the power button. Notice the small plastic ring that sticks out the side, this is so the piece can be positioned easily when you put it back together.
      • In the second picture, the volume control button is shown. Again notice the small locator rings.
      Vraag FixBot
      Voeg opmerking toe
    5. Zeepad 7DRK Charging Port  Replacement: stap 5, afbeelding 1 van 2 Zeepad 7DRK Charging Port  Replacement: stap 5, afbeelding 2 van 2
      • Now remove the old or broken buttons, and replace them.
      Vraag FixBot
      Voeg opmerking toe
    1. Zeepad 7DRK Charging Port  Replacement, Charging Port: stap 6, afbeelding 1 van 1
      • With the two halves of the tablet apart, you will see the motherboard. It is held on by three screws as well as three wire strips.
      Vraag FixBot
      Voeg opmerking toe
    2. Zeepad 7DRK Charging Port  Replacement: stap 7, afbeelding 1 van 1
      • Remove the pieces of tape attached to the motherboard so that it can be taken off.
      Vraag FixBot
      Voeg opmerking toe
    3. Zeepad 7DRK Charging Port  Replacement: stap 8, afbeelding 1 van 3 Zeepad 7DRK Charging Port  Replacement: stap 8, afbeelding 2 van 3 Zeepad 7DRK Charging Port  Replacement: stap 8, afbeelding 3 van 3
      • There are three wire strips that connect to the motherboard via small plastic clips. they connect to the backlight, battery, and screen shown in the first image.
      • To detach the two connections on the left, for the screen and back-light, you must slide two blue tabs on either side of the wire strip upwards as shown in the second and third image.
      Vraag FixBot
      Voeg opmerking toe
    4. Zeepad 7DRK Charging Port  Replacement: stap 9, afbeelding 1 van 3 Zeepad 7DRK Charging Port  Replacement: stap 9, afbeelding 2 van 3 Zeepad 7DRK Charging Port  Replacement: stap 9, afbeelding 3 van 3
      • Take out the screws using a small phillip's head bit. The three locations of the screws are shown.
      • Be careful with the screw as they are small and easy to lose. Put them in a magnetic holder if possible.
      Vraag FixBot
      Voeg opmerking toe
    5. Zeepad 7DRK Charging Port  Replacement: stap 10, afbeelding 1 van 1
      • For the third connection, to the battery, the plastic piece that holds the wire strip in has a blue tab that rotates upward to release. The pivot point on one side is shown using the screw driver.
      Vraag FixBot
      Voeg opmerking toe
    6. Zeepad 7DRK Charging Port  Replacement: stap 11, afbeelding 1 van 1
      • With all the plastic pieces that hold the wire strips in place loosened, you can take the wire strips out and remove the motherboard form the rest of the tablet.
      • Be careful not to break any of the other wired connections on the device.
      • Place it upside down on your work space and you will see the charging port.
      Vraag FixBot
      Voeg opmerking toe
    7. Zeepad 7DRK Charging Port  Replacement: stap 12, afbeelding 1 van 3 Zeepad 7DRK Charging Port  Replacement: stap 12, afbeelding 2 van 3 Zeepad 7DRK Charging Port  Replacement: stap 12, afbeelding 3 van 3
      • The charging port is soldered onto the motherboard in four locations.
      • There are two points on the inward facing side as shown in the first image, and there is one point on either side of the port.
      • To completely remove the port, use a soldering iron to melt the solder holding on the port and gently disconnect the port form the motherboard.
      • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Trevor Taylor
234 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 6-8, Martin Fall 2016 Lid van UMass Dartmouth, Team 6-8, Martin Fall 2016
UMASSD-MARTIN-F16S6G8
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 685
