Ga door naar hoofdinhoud
ZTE Tempo Headphone Jack Replacement
Wat je nodig hebt
  1. ZTE Tempo Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 1 van 2 ZTE Tempo Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 2 van 2
    • Pry open the back case to get to the back cover.
    • Remove eight 5mm screws with a PH0 screw.
    • Pry open the back cover with a plastic opening tool.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the back cover.
    • Note: Pry open by finding an edge and forcing it open with the plastic opening tool.
  2. ZTE Tempo Headphone Jack Replacement: stap 2, afbeelding 1 van 3 ZTE Tempo Headphone Jack Replacement: stap 2, afbeelding 2 van 3 ZTE Tempo Headphone Jack Replacement: stap 2, afbeelding 3 van 3
    • Unplug wires by pushing up with the plastic opening tool
  3. ZTE Tempo Headphone Jack Replacement: stap 3, afbeelding 1 van 2 ZTE Tempo Headphone Jack Replacement: stap 3, afbeelding 2 van 2
    • Push up with the plastic opening tool to remove the motherboard.
    • Slide the plastic opening tool alongside the side seam twisting your hand forcefully to open the motherboard.
  4. ZTE Tempo Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • Unplug the wire by pushing up with the plastic opening tool in the back of the motherboard.
  5. ZTE Tempo Headphone Jack Replacement: stap 5, afbeelding 1 van 2 ZTE Tempo Headphone Jack Replacement: stap 5, afbeelding 2 van 2
    • Desolder and remove in front of the motherboard.
Conclusie
omar
717 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 165
