Ga door naar hoofdinhoud
ZTE Max XL Front-Facing Camera Replacement
Wat je nodig hebt
  1. ZTE Max XL Front-Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 1 van 2 ZTE Max XL Front-Facing Camera Replacement, Front-Facing Camera: stap 1, afbeelding 2 van 2
    • Before disassembly, assure the phone is powered off.
    • Use the SIM Card remover key, remove the SIM Card tray. To do this insert the key into the hole on the side of the phone near the SIM Card tray.
    Vraag FixBot
    Voeg opmerking toe
  2. ZTE Max XL Front-Facing Camera Replacement: stap 2, afbeelding 1 van 2 ZTE Max XL Front-Facing Camera Replacement: stap 2, afbeelding 2 van 2
    • Apply the iOpener to the back of the phone. For instructions of how to use the iOpener, use this guide.
    • On our phone there was adhesive on the top and bottom of the phone backing, so we specifically heated these areas.
    • Do not heat the phone too much in one area - it may warp the plastic backing.
    Vraag FixBot
    Voeg opmerking toe
  3. ZTE Max XL Front-Facing Camera Replacement: stap 3, afbeelding 1 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 3, afbeelding 2 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Start at one corner, and use the plastic opening pick from the iFixit kit to wedge underneath the plastic backing to start undoing the tabs that connect the backing to the phone. There are 3 tabs on top and bottom and 6 on each side.
    • Use extreme caution to not puncture the lithium ion battery.
    Vraag FixBot
    Voeg opmerking toe
  4. ZTE Max XL Front-Facing Camera Replacement: stap 4, afbeelding 1 van 2 ZTE Max XL Front-Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Carefully undo the ribbon wire for the fingerprint scanner before full removal of the backing.
    • There are two 3.4mm JIS #00 screws that hold the wire in place, one may be under a lock sticker. Remove the screws with the JIS #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  5. ZTE Max XL Front-Facing Camera Replacement: stap 5, afbeelding 1 van 2 ZTE Max XL Front-Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • After removal of the two 3.4mm JIS #00 screws, disconnect the connector that attaches the ribbon wire from the main part of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. ZTE Max XL Front-Facing Camera Replacement: stap 6, afbeelding 1 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 6, afbeelding 2 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 6, afbeelding 3 van 3
    • Remove the nineteen 3.4mm JIS #00 screws on the perimeter of the back using the JIS #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. ZTE Max XL Front-Facing Camera Replacement: stap 7, afbeelding 1 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 7, afbeelding 2 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic pick between the screen and side trim battery cover to remove the screen.
    • If the SIM Card is still in place during removal of the siding, take care during removal to avoid damaging the SIM Card.
    Vraag FixBot
    Voeg opmerking toe
  8. ZTE Max XL Front-Facing Camera Replacement: stap 8, afbeelding 1 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 8, afbeelding 2 van 3 ZTE Max XL Front-Facing Camera Replacement: stap 8, afbeelding 3 van 3
    • Now there is access to the phone's components; use the spudger to flip the metal connector to release the camera.
    • The camera itself is lightweight so take care during the removal of the connector not to lose it.
    Vraag FixBot
    Voeg opmerking toe
  9. ZTE Max XL Front-Facing Camera Replacement: stap 9, afbeelding 1 van 1
    • With the metal connector detached, the camera is fully disconnected from the phone and ready to be replaced.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Olivia Wolf
1.400 Reputatie
5 handleidingen geschreven
UW Stout, Team S8-G2, Ogden Spring 2018 Lid van UW Stout, Team S8-G2, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G2
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 623
