Ga door naar hoofdinhoud
Xiaomi Mi Watch 2021 Motherboard Replacement
Wat je nodig hebt
  1. Xiaomi Mi Watch 2021 Motherboard Replacement, Unfasten the screws: stap 1, afbeelding 1 van 1
    • Opening the Mi Watch will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your watch without replacing the seals.
    • Before starting the disassembly, turn off your watch.
    • Remove the four 3.2 mm-long T3 Torx screws on the back of the watch.
    • A T3 screwdriver has a tight fit on these screws and might require a bit more downward pressure to unfasten the screws. A T2 fits as well but poses the risk to strip the screw heads.
  2. Xiaomi Mi Watch 2021 Motherboard Replacement, Create a small gap: stap 2, afbeelding 1 van 3 Xiaomi Mi Watch 2021 Motherboard Replacement, Create a small gap: stap 2, afbeelding 2 van 3 Xiaomi Mi Watch 2021 Motherboard Replacement, Create a small gap: stap 2, afbeelding 3 van 3
    • Insert the flat end of a spudger into the loudspeaker opening at the top edge of the rear case assembly.
    • Push the spudger upwards to create a small gap between the rear case assembly and the watch housing.
  3. Xiaomi Mi Watch 2021 Motherboard Replacement, Pry up the rear case: stap 3, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Pry up the rear case: stap 3, afbeelding 2 van 2
    • Insert your spudger into the gap and pry up the rear case assembly.
    • Only work with the edge of your spudger and do not insert it deeper than 3 mm.
    • Steady the rear case assembly with a finger to prevent it from suddenly popping open and damaging the flex cable.
    • Don’t try to remove the rear case assembly all the way yet. It is still connected to the motherboard with a thin flex cable.
  4. Xiaomi Mi Watch 2021 Motherboard Replacement, Open the watch assembly: stap 4, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Open the watch assembly: stap 4, afbeelding 2 van 2
    • Carefully swing open the rear case assembly by folding the rear case to the side with the watch buttons.
    • Avoid straining the flex cable during this procedure.
  5. Xiaomi Mi Watch 2021 Motherboard Replacement, Unfasten the screw: stap 5, afbeelding 1 van 1
    • Remove the 2.7 mm-long Phillips screw securing the metal bracket in the top right corner of your watch.
  6. Xiaomi Mi Watch 2021 Motherboard Replacement, Remove the metal bracket: stap 6, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Remove the metal bracket: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
  7. Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the rear case assembly: stap 7, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the rear case assembly: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the rear case assembly flex connector from the motherboard.
  8. Xiaomi Mi Watch 2021 Motherboard Replacement, Unfasten the screw: stap 8, afbeelding 1 van 1
    • Remove the 2.7 mm-long Phillips screw securing the metal bracket at the bottom left corner of your watch.
  9. Xiaomi Mi Watch 2021 Motherboard Replacement, Remove the metal bracket: stap 9, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Remove the metal bracket: stap 9, afbeelding 2 van 2
    • Use a pair of tweezers to unhinge the little hook at the upper end of the metal bracket and remove it.
    • During reassembly, make sure to latch the metal bracket.
  10. Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the watch buttons: stap 10, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the watch buttons: stap 10, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the watch button flex connector.
  11. Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the screen and digitizer: stap 11, afbeelding 1 van 3 Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the screen and digitizer: stap 11, afbeelding 2 van 3 Xiaomi Mi Watch 2021 Motherboard Replacement, Disconnect the screen and digitizer: stap 11, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the screen and the digitizer flex connectors.
  12. Xiaomi Mi Watch 2021 Motherboard Replacement, Unfasten the screws: stap 12, afbeelding 1 van 1
    • Remove the two 2.7 mm-long Phillips screws securing the motherboard.
  13. Xiaomi Mi Watch 2021 Motherboard Replacement, Remove the motherboard: stap 13, afbeelding 1 van 2 Xiaomi Mi Watch 2021 Motherboard Replacement, Remove the motherboard: stap 13, afbeelding 2 van 2
    • Use a pair of tweezers to lift the motherboard out of the watch housing.
    • Avoid damaging the surrounding flex cables during this procedure.
Conclusie
If possible, turn on your device and test your repair before resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answer Community for help.
Dominik Schnabelrauch
230.209 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.537 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 18
Altijd: 1,304
