Inleiding
Use this guide to remove or replace the motherboard cover in the Xiaomi Mi 8 including the NFC antenna.
You’ll need replacement adhesive to reattach components when reassembling the device.
Wat je nodig hebt
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a third opening pick at the bottom left corner.
Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Remove the ten screws that secure the motherboard cover.
Eight Phillips #00 screws (3.4 mm length)
Two Phillips #00 screws (3.5 mm length)
5 andere personen hebben deze handleiding voltooid.
