Inleiding
Use this guide to replace the Wi-Fi board on an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Wat je nodig hebt
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm-long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm pancake screw
Two 8.8 mm screws
Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
Grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
Lift up the optical drive's vibration isolator to remove it.
Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
Use your fingers to pull up and disconnect the data cable from the optical drive.
Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
Gently peel the taped USB port ribbon cable off of the heatsink.
Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
Lift out the center chassis assembly to remove it from the shell.
Unlatch the chassis strap from the right side of the power supply.
Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
Two 13.1 mm screws
One 35 mm screw
Unlatch and open the lid on the power cable's plastic guide.
Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
Use a T8 Torx driver to remove the nine screws securing the board shield:
Six 8.8 mm black screws
Two 35 mm silver screws
One 13.1 mm silver screw
Disconnect the chassis strap from the locking tabs on either side of the power supply.
Grip and compress the locking tab on the 10-pin power connector.
While compressing the locking tab, lift the connector straight up to disconnect it from the board.
Grip and compress the locking tab on the 2-pin power connector.
Use a T8 Torx driver to remove the four screws securing the power supply around its perimeter:
Three 35 mm silver screws
One 8.8 mm black screw
Use a T8 Torx driver to remove the three 8.8 mm screws securing the Wi-Fi antenna board.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Will wired internet still work if you remove and don't replace the wifi board?
