Ga door naar hoofdinhoud
Xbox Series X Accessory Antenna Board Replacement
Wat je nodig hebt
  1. Xbox Series X Accessory Antenna Board Replacement, Uncover the back panel screws: stap 1, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement, Uncover the back panel screws: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Accessory Antenna Board Replacement: stap 2, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement: stap 2, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement: stap 2, afbeelding 3 van 3
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Accessory Antenna Board Replacement, Remove the back panel screws: stap 3, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    Koop
    • Use a T8 Torx driver to remove the two 7.4 mm-long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Accessory Antenna Board Replacement, Unclip the back panel: stap 4, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Unclip the back panel: stap 4, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Unclip the back panel: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Accessory Antenna Board Replacement: stap 5, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement: stap 5, afbeelding 2 van 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Accessory Antenna Board Replacement, Remove the back panel: stap 6, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the back panel: stap 6, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the back panel: stap 6, afbeelding 3 van 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Accessory Antenna Board Replacement: stap 7, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement: stap 7, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement: stap 7, afbeelding 3 van 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Accessory Antenna Board Replacement, Remove the fan screws: stap 8, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X Accessory Antenna Board Replacement, Disconnect the fan cable: stap 9, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the fan cable: stap 9, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the fan cable: stap 9, afbeelding 3 van 3
    Koop
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X Accessory Antenna Board Replacement, Remove the fan: stap 10, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement, Remove the fan: stap 10, afbeelding 2 van 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you are replacing the fan, a new fan will probably not include the plastic installation bracket. The bracket is attached to the fan with four T10 Torx screws. This is not pictured in this guide.
  11. Xbox Series X Accessory Antenna Board Replacement, Unlatch the base: stap 11, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Unlatch the base: stap 11, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Unlatch the base: stap 11, afbeelding 3 van 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Accessory Antenna Board Replacement, Twist and remove the base: stap 12, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Twist and remove the base: stap 12, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Twist and remove the base: stap 12, afbeelding 3 van 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X Accessory Antenna Board Replacement, Remove the optical drive screws: stap 13, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement, Remove the optical drive screws: stap 13, afbeelding 2 van 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Accessory Antenna Board Replacement, Remove the vibration isolator: stap 14, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the vibration isolator: stap 14, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the vibration isolator: stap 14, afbeelding 3 van 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Accessory Antenna Board Replacement, Disconnect the power and data cables: stap 15, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the power and data cables: stap 15, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the power and data cables: stap 15, afbeelding 3 van 3
    Koop
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X Accessory Antenna Board Replacement, Remove the optical drive: stap 16, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement, Remove the optical drive: stap 16, afbeelding 2 van 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Accessory Antenna Board Replacement, Disconnect the USB port cable: stap 17, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the USB port cable: stap 17, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the USB port cable: stap 17, afbeelding 3 van 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Accessory Antenna Board Replacement: stap 18, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement: stap 18, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, apply an iOpener or carefully heat it with a hair dryer to soften the adhesive.
  19. Xbox Series X Accessory Antenna Board Replacement, Disconnect the power button cable: stap 19, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the power button cable: stap 19, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Disconnect the power button cable: stap 19, afbeelding 3 van 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X Accessory Antenna Board Replacement, Remove the chassis screws: stap 20, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Accessory Antenna Board Replacement, Peel up the USB port cable: stap 21, afbeelding 1 van 2 Xbox Series X Accessory Antenna Board Replacement, Peel up the USB port cable: stap 21, afbeelding 2 van 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
  22. Xbox Series X Accessory Antenna Board Replacement, Remove the center chassis assembly: stap 22, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the center chassis assembly: stap 22, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the center chassis assembly: stap 22, afbeelding 3 van 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Accessory Antenna Board Replacement, Remove the antenna board screws: stap 23, afbeelding 1 van 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the antenna board to the center chassis.
  24. Xbox Series X Accessory Antenna Board Replacement, Remove the accessory antenna board: stap 24, afbeelding 1 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the accessory antenna board: stap 24, afbeelding 2 van 3 Xbox Series X Accessory Antenna Board Replacement, Remove the accessory antenna board: stap 24, afbeelding 3 van 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
5 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
114.671 Reputatie
339 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.303 handleidingen geschreven
2 opmerkingen
Had a Xbox Series X with a completely non-functional sync button, xbox light did not blink upon pressing it. Controllers or other Xbox wireless accessories did not work either. Replacing this board fixed that issue! In case anyone else runs into the same problem.
Nicolas Sloan - Antwoord
This was extremely well described. For me, however it did not solve my problem. I solved my controller connectivity and wifi issue simply by plugging in a powered external hard drive into the front USB of my Xbox Series X. It appears that possibly the power supply was not generating enough power and this little boost has sorted it. It only worked after I connected the external powered drive and then rebooted.
Rikki - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 77
Afgelopen 30 dagen: 266
Altijd: 5,625
