Ga door naar hoofdinhoud
Xbox Series S Plastic Case Replacement
Wat je nodig hebt
  1. Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: stap 1, afbeelding 1 van 3 Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: stap 1, afbeelding 2 van 3 Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
    Where can I get a shell replacement?
    King DK - Antwoord
  2. Xbox Series S Plastic Case Replacement, Remove the back panel screws: stap 2, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Plastic Case Replacement, Remove the bottom panel: stap 3, afbeelding 1 van 3 Xbox Series S Plastic Case Replacement, Remove the bottom panel: stap 3, afbeelding 2 van 3 Xbox Series S Plastic Case Replacement, Remove the bottom panel: stap 3, afbeelding 3 van 3
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Plastic Case Replacement, Remove the plastic case screws: stap 4, afbeelding 1 van 1
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Plastic Case Replacement, Remove the plastic case: stap 5, afbeelding 1 van 3 Xbox Series S Plastic Case Replacement, Remove the plastic case: stap 5, afbeelding 2 van 3 Xbox Series S Plastic Case Replacement, Remove the plastic case: stap 5, afbeelding 3 van 3
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Plastic Case Replacement: stap 6, afbeelding 1 van 3 Xbox Series S Plastic Case Replacement: stap 6, afbeelding 2 van 3 Xbox Series S Plastic Case Replacement: stap 6, afbeelding 3 van 3
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
8 andere personen hebben deze handleiding voltooid.
Robert Boyd
29.454 Reputatie
94 handleidingen geschreven
3Gids Commentaar
Where can i find custom case for the xbox series s?
Joe - Antwoord
What about the back plate?
Legitti - Antwoord
it says you cant remove it
Pavement Creator - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 29
Afgelopen 7 dagen: 255
Afgelopen 30 dagen: 1,304
Altijd: 39,825
