Ga door naar hoofdinhoud
Xbox One Wireless Controller Model 1708 Top Motherboard Replacement
Wat je nodig hebt
  1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: stap 1, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: stap 1, afbeelding 2 van 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 2, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Vraag FixBot
    Voeg opmerking toe
  3. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Vraag FixBot
    Voeg opmerking toe
  4. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 4, afbeelding 1 van 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
    Vraag FixBot
    Voeg opmerking toe
  5. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: stap 6, afbeelding 1 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: stap 6, afbeelding 2 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: stap 6, afbeelding 3 van 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    Vraag FixBot
    Voeg opmerking toe
  7. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Directional Pad: stap 7, afbeelding 1 van 1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
    Vraag FixBot
    Voeg opmerking toe
  8. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Joystick Caps: stap 8, afbeelding 1 van 1
    • Pull the joysticks off of the controller.
    Vraag FixBot
    Voeg opmerking toe
  9. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Top Motherboard: stap 9, afbeelding 1 van 1
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
    Vraag FixBot
    Voeg opmerking toe
  10. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: stap 10, afbeelding 1 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: stap 10, afbeelding 2 van 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: stap 10, afbeelding 3 van 3
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
25 andere personen hebben deze handleiding voltooid.
Lien (Ally) Quan
1.095 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G3, Forte Fall 2017 Lid van Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Leden
42 handleidingen geschreven
1Gids Commentaar
Necesito un diagrama donde pueda ver el esquemático de los vibradores del gatillo
Héctor Bohórquez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 69
Afgelopen 30 dagen: 385
Altijd: 36,233
