Ga door naar hoofdinhoud
Whirlpool Refrigerator Start Relay Assembly Replacement
Wat je nodig hebt
  1. Whirlpool Refrigerator Start Relay Assembly Replacement, Safety precautions: stap 1, afbeelding 1 van 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: stap 2, afbeelding 1 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: stap 2, afbeelding 2 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unfasten the rear panel: stap 2, afbeelding 3 van 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: stap 3, afbeelding 1 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: stap 3, afbeelding 2 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the rear panel: stap 3, afbeelding 3 van 3
    • Pull the rear panel off the chassis to remove it.
  4. Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: stap 4, afbeelding 1 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: stap 4, afbeelding 2 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Disconnect the start relay assembly: stap 4, afbeelding 3 van 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any connectors attached to the start relay assembly.
  5. Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: stap 5, afbeelding 1 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: stap 5, afbeelding 2 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Unclip the start relay assembly: stap 5, afbeelding 3 van 3
    • Pull the metal clip out its hole in the top of the start relay assembly.
    • Rest the clip next to the assembly.
  6. Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: stap 6, afbeelding 1 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: stap 6, afbeelding 2 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Remove the start relay assembly: stap 6, afbeelding 3 van 3
    • Pull the start relay assembly straight off its prongs in the chassis.
    • Remove the start relay assembly.
    • The assembly consists of the run capacitor, start relay, and overload relay.
  7. Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: stap 7, afbeelding 1 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: stap 7, afbeelding 2 van 3 Whirlpool Refrigerator Start Relay Assembly Replacement, Meter the start relay assembly: stap 7, afbeelding 3 van 3
    • If you own a multimeter, you can test the start relay and overload relay's resistance.
    • A range between 0–1 Ω for the overload relay, and 0–5 Ω for the start relay is acceptable.
Conclusie
Repair didn’t go as planned? Ask our Answers community for help.
5 andere personen hebben deze handleiding voltooid.
nicO
15.945 Reputatie
89 handleidingen geschreven
2Gids Commentaar
While the parts are similar, there are differences for fridges. If you can find your refrigerator model number, you'll be able to search online for the correct start relay for your specific model. Good luck!
nicO -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 62
Afgelopen 30 dagen: 311
Altijd: 14,024
