Ga door naar hoofdinhoud
Wacom Intuos Pro Battery Replacement
Wat je nodig hebt
  1. Wacom Intuos Pro Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Wacom Intuos Pro Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Wacom Intuos Pro Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
    Vraag FixBot
    Voeg opmerking toe
  2. Wacom Intuos Pro Battery Replacement: stap 2, afbeelding 1 van 3 Wacom Intuos Pro Battery Replacement: stap 2, afbeelding 2 van 3 Wacom Intuos Pro Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
    • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
    Vraag FixBot
    Voeg opmerking toe
  3. Wacom Intuos Pro Battery Replacement: stap 3, afbeelding 1 van 2 Wacom Intuos Pro Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
    Vraag FixBot
    Voeg opmerking toe
  4. Wacom Intuos Pro Battery Replacement: stap 4, afbeelding 1 van 2 Wacom Intuos Pro Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
    Vraag FixBot
    Voeg opmerking toe
  5. Wacom Intuos Pro Battery Replacement: stap 5, afbeelding 1 van 2 Wacom Intuos Pro Battery Replacement: stap 5, afbeelding 2 van 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
7Gids Commentaar
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - Antwoord Deel
Do you know where can I find the battery replacement?
Valerio _ - Antwoord Deel
Has anyone got a lint to the replacement battery?
Luca Di Meo - Antwoord Deel
PTH-660 works fine without the battery, just remove it and use it with USB cable
Where can I find a replacement battery for this model?
Denise Hanly - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 182
Altijd: 11,693
