Ga door naar hoofdinhoud
Vtech Kidizoom Smart Watch DX Buttons Replacement
Wat je nodig hebt
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: stap 1, afbeelding 1 van 1
      • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
      • Flip the watch over with the back facing up.
      Vraag FixBot
      Voeg opmerking toe
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 2, afbeelding 1 van 1
      • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 3, afbeelding 1 van 1
      • Gently pull the back plate from the watch casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 4, afbeelding 1 van 2 Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 4, afbeelding 2 van 2
      • Lift the master switch from the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: stap 5, afbeelding 1 van 2 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: stap 5, afbeelding 2 van 2
      • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
      • Removal of the circuit board requires soldering.
      • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
      Vraag FixBot
      Voeg opmerking toe
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 6, afbeelding 1 van 1
      • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 7, afbeelding 1 van 1
      • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
      • De-solder the black speaker wire from the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 8, afbeelding 1 van 1
      • De-solder the red speaker wire, as in the previous step.
      Vraag FixBot
      Voeg opmerking toe
    5. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 9, afbeelding 1 van 1
      • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: stap 10, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use the the tweezers to pull off the blue rubber cover behind the button.
      • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
      Vraag FixBot
      Voeg opmerking toe
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 11, afbeelding 1 van 1
      • Use tweezers to separate the backside tab from the front side of the button.
      Vraag FixBot
      Voeg opmerking toe
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: stap 12, afbeelding 1 van 1
      • Push the other half of the button out of the casing.
      • Repeat steps 11 and 12 for all buttons.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mohammed Alyaarubi
365 Reputatie
1 Handleiding geschreven
USF Tampa, Team 10-6, Remmell Spring 2016 Lid van USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Where can you buy the replacement cover?
Katrina Nullatamby - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 51
Altijd: 6,547
