Ga door naar hoofdinhoud
VTechCS6719-16 Speaker Replacement
Wat je nodig hebt
  1. VTechCS6719-16 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the sliding cover on the back of the phone case.
    Vraag FixBot
    Voeg opmerking toe
  2. VTechCS6719-16 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Now remove the battery by lifting it and removing the two pin cable.
    Vraag FixBot
    Voeg opmerking toe
  3. VTechCS6719-16 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the two 10mm screws on the back of the phone base.
    Vraag FixBot
    Voeg opmerking toe
  4. VTechCS6719-16 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using the metal spudger edge along the phone and locate the hooks and latches.
    • Locating each of them apply a light but firm lifting force to release the front and back case.
    Vraag FixBot
    Voeg opmerking toe
  5. VTechCS6719-16 Speaker Replacement: stap 5, afbeelding 1 van 1
    • The front case should now be freed.
    • Put the front case aside for later.
    Vraag FixBot
    Voeg opmerking toe
  6. VTechCS6719-16 Speaker Replacement: stap 6, afbeelding 1 van 1
    • There are two 10mm screws located at the top of the circuit board.
    • Unscrewing the screws allows for access to the speaker.
    Vraag FixBot
    Voeg opmerking toe
  7. VTechCS6719-16 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Flipping the circuit board will expose the speaker rested in the white LCD base.
    • Gently using the scoop end of the spudger will free the speaker from the dock.
    • Careful not to jerk the speaker as it is still attached to the board.
    Vraag FixBot
    Voeg opmerking toe
  8. VTechCS6719-16 Speaker Replacement: stap 8, afbeelding 1 van 1
    • The last portion of this will require soldering skills. Simply solder the speaker from the board and replace with desired speaker.
    • If this is your first time soldering, check out this useful soldering guide.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Charles montes
513 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-5, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 463
