Ga door naar hoofdinhoud
VTech Safe and Sound DM111-2 Baby Unit Motherboard replacement Guide
Wat je nodig hebt
    1. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Baby Unit Motherboard replacement Guide: stap 1, afbeelding 1 van 1
      • Along the back of unit there are two 4mm philips head screws towards the bottom of the unit. Start by removing these two screws using your PH0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 2, afbeelding 1 van 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 2, afbeelding 2 van 2
      • Using the plastic spudger gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
      • Unlike the parent unit there are no wires across the two housing pieces, so once the latches are undone simply pull it apart without worry of disconnecting anything.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 3, afbeelding 1 van 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 3, afbeelding 2 van 2
      • Once apart the motherboard will be exposed with two 4mm phillips head screws near the top and 4 wires leading leading to a circuit board hidden under the motherboard.
      • Remove the two screws near the top of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: stap 4, afbeelding 1 van 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: stap 4, afbeelding 2 van 2
      • Remove the strip of adhesive tape located under the motherboard.
      • Gently lift the motherboard to expose the inner components.
      • Use a spudger to scrape away the adhesive and foam connecting the microphone.
      • Unscrew the 4mm phillips head screw holding the microphone in place.
      Vraag FixBot
      Voeg opmerking toe
    5. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 5, afbeelding 1 van 3 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 5, afbeelding 2 van 3 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Desoldering Pump
      $3.99
      • Before de-soldering, check to see no scorching or broken connections appear on the wires, power supply jack or antenna.
      • De-solder the connections from the motherboard using a soldering iron and a solder sucker.
      • De-solder the connections to the microphone, located on the bottom left of the mother board.
      • De-solder the 4 wires connecting the LED board to the motherboard.
      • De-solder the antenna's solder joint, located above the microphone wire connection.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jean Carlos
201 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-3, Remmell Fall 2015 Lid van USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 1,329
