Ga door naar hoofdinhoud
VTech Little Apps Tablet Speaker Replacement
Wat je nodig hebt
    1. VTech Little Apps Tablet Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Little Apps Tablet Speaker Replacement: stap 2, afbeelding 1 van 1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech Little Apps Tablet Speaker Replacement, Back Cover: stap 3, afbeelding 1 van 2 VTech Little Apps Tablet Speaker Replacement, Back Cover: stap 3, afbeelding 2 van 2
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Little Apps Tablet Speaker Replacement: stap 4, afbeelding 1 van 2 VTech Little Apps Tablet Speaker Replacement: stap 4, afbeelding 2 van 2
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      Vraag FixBot
      Voeg opmerking toe
    1. VTech Little Apps Tablet Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 VTech Little Apps Tablet Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
      • The speaker should be located at the bottom-right side of the back cover from your perspective.
      • Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
      • Be careful not to disturb the wires while removing the screws.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Little Apps Tablet Speaker Replacement: stap 6, afbeelding 1 van 2 VTech Little Apps Tablet Speaker Replacement: stap 6, afbeelding 2 van 2
      • Remove the speaker from its holding and place it to the side of the device.
      • Desolder the brown wires from the speaker connections.
      • Soldering is the most difficult step in this guide. If you are in need of assistance with this step, refer to this Soldering Guide.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Johnnie Cairns
522 Reputatie
4 handleidingen geschreven
USF Tampa, Team 2-6, Sullivan Spring 2016 Lid van USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 37
Altijd: 1,593
