Inleiding
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
Wat je nodig hebt
Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
Één andere persoon heeft deze handleiding voltooid.
