Ga door naar hoofdinhoud
VTech Baby's Learning Laptop LEDs Replacement
Wat je nodig hebt
    1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: stap 1, afbeelding 1 van 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Vraag FixBot
      Voeg opmerking toe
    2. VTech Baby's Learning Laptop LEDs Replacement: stap 2, afbeelding 1 van 1
      • Remove the battery door.
      • Take out the batteries.
      Vraag FixBot
      Voeg opmerking toe
    3. VTech Baby's Learning Laptop LEDs Replacement: stap 3, afbeelding 1 van 2 VTech Baby's Learning Laptop LEDs Replacement: stap 3, afbeelding 2 van 2
      • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
      Vraag FixBot
      Voeg opmerking toe
    4. VTech Baby's Learning Laptop LEDs Replacement: stap 4, afbeelding 1 van 3 VTech Baby's Learning Laptop LEDs Replacement: stap 4, afbeelding 2 van 3 VTech Baby's Learning Laptop LEDs Replacement: stap 4, afbeelding 3 van 3
      • With the lid closed, position the device such that the handle is pointing towards you.
      • Using your fingers, gently pry open the cover from the hinge.
      • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
      Vraag FixBot
      Voeg opmerking toe
    5. VTech Baby's Learning Laptop LEDs Replacement: stap 5, afbeelding 1 van 1
      • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. VTech Baby's Learning Laptop LEDs Replacement: stap 6, afbeelding 1 van 1
      • Pickup the array by the opening in the center of the board.
      • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
      • Movement of the array will be limited as it is still attached to the main device board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Christopher Kourmoulakis
412 Reputatie
3 handleidingen geschreven
USF Tampa, Team 12-2, Blackwell Fall 2015 Lid van USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 1,566
