Ga door naar hoofdinhoud
Tungsten E Power Button Repair
Wat je nodig hebt
    1. Tungsten E Power Button Repair, Tungsten E Disassembly: stap 1, afbeelding 1 van 2 Tungsten E Power Button Repair, Tungsten E Disassembly: stap 1, afbeelding 2 van 2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      Vraag FixBot
      Voeg opmerking toe
    2. Tungsten E Power Button Repair: stap 2, afbeelding 1 van 3 Tungsten E Power Button Repair: stap 2, afbeelding 2 van 3 Tungsten E Power Button Repair: stap 2, afbeelding 3 van 3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      Vraag FixBot
      Voeg opmerking toe
    3. Tungsten E Power Button Repair: stap 3, afbeelding 1 van 2 Tungsten E Power Button Repair: stap 3, afbeelding 2 van 2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Tungsten E Power Button Repair: stap 4, afbeelding 1 van 2 Tungsten E Power Button Repair: stap 4, afbeelding 2 van 2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      Vraag FixBot
      Voeg opmerking toe
    5. Tungsten E Power Button Repair: stap 5, afbeelding 1 van 3 Tungsten E Power Button Repair: stap 5, afbeelding 2 van 3 Tungsten E Power Button Repair: stap 5, afbeelding 3 van 3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      Vraag FixBot
      Voeg opmerking toe
    6. Tungsten E Power Button Repair: stap 6, afbeelding 1 van 1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      Vraag FixBot
      Voeg opmerking toe
    1. Tungsten E Power Button Repair, Tungsten E Power Button Repair: stap 7, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    2. Tungsten E Power Button Repair: stap 8, afbeelding 1 van 1
      • On the motherboard, find the power button near the upper right corner.
      • Check for disconnection of the power button.
      Vraag FixBot
      Voeg opmerking toe
    3. Tungsten E Power Button Repair: stap 9, afbeelding 1 van 1
      • Use soldering iron to reattach the damaged power button to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kathleen Hix
49 Reputatie
2 handleidingen geschreven
Cal Poly, Team 13-22, Maness Winter 2010 Lid van Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 5,628
