Ga door naar hoofdinhoud
Toshiba Tecra Z50-A Battery Replacement
Wat je nodig hebt
  1. Toshiba Tecra Z50-A Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Battery Replacement: stap 2, afbeelding 1 van 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Battery Replacement: stap 7, afbeelding 1 van 1
    • Lift up on the battery with your hands and remove it from the laptop.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Één andere persoon heeft deze handleiding voltooid.
Dominic Hryzan
545 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 966
