Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the laptop to the bottom side.
Locate and slide the two battery locks to disconnect the battery.
Remove the battery by sliding it out away from the computer (horizontal with the casing).
Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
Then, use a the blue iFixit Opening Tool to pry the cover panel off.
Push on to the RAM tabs to disconnect the RAM form the device.
The RAM will pop off from the socket. Gently pull the RAM out of the socket.
Use the #1 Phillips head screwdriver to unscrew the panel.
Disconnect the black and white wires.
Push on the tabs to disconnect the Wi-Fi card.
Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
Use the #1 Phillips head screwdriver as to remove the hard drive screw.
Use the blue iFixit Opening Tool to pry the cover off.
Use the plastic flap to pull the hard drive out of its slot.
Use the #1 Phillips head screwdriver remove the Optical Drive screw.
Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
Use your hands to pull the rest of the Optical Drive out.
Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
Push back the screen until it is flat with the laptop.
Gently remove the clips that connect the panel to the screen.
Use the Phillips #1 screwdriver to remove the two screws.
Gently pry the keyboard from the laptop using the blue iFixit opening tool.
Slowly lift the keyboard away from the laptop.
Remove the ribbon that connects to the laptop.
Disconnect the video cable, then slowly and firmly pull the video cable upwards.
Disconnect the brown ribbon located in the middle area of the laptop.
Disconnect the two white ribbons located in the bottom left of the laptop.
Firmly pull out the two white ribbons.
Use the Phillips #00 Screwdriver to unscrew all the screws.
Unscrew three additional screws through the three holes on the optical drive.
Turn the laptop upside down.
Use the blue iFixit Opening Tool to slowly pry the case upward.
Remove the white ribbon
Één andere persoon heeft deze handleiding voltooid.
