Ga door naar hoofdinhoud
Toshiba Satellite A65-S126 Optical Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A65-S126 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Optical Drive Replacement, Upper Assembly: stap 3, afbeelding 1 van 1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite A65-S126 Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Optical Drive Replacement, Optical Drive: stap 9, afbeelding 1 van 1
    • Orient the bottom assembly as displayed.
  10. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite A65-S126 Optical Drive Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 3 mm Phillips #00 screws.
  11. Toshiba Satellite A65-S126 Optical Drive Replacement: stap 11, afbeelding 1 van 1
    • Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
Conclusie
Geoff Wacker
88.953 Reputatie
89 handleidingen geschreven
Één opmerking
Or, simply remove the screw (the center one in this photo) from the bottom case that holds the bracket in and pull the drive out.
J Howard Markley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 940
