Ga door naar hoofdinhoud
Teddy Ruxpin Motherboard Replacement
Wat je nodig hebt
    1. Teddy Ruxpin Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Teddy Ruxpin Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
      • Remove the vest covering the back of the bear.
      • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
      • Captured screws will stay in place, no need to worry about losing this one!
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Pull the tab outward to remove the protective plate for the batteries.
      Vraag FixBot
      Voeg opmerking toe
    3. Teddy Ruxpin Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
      Vraag FixBot
      Voeg opmerking toe
    1. Teddy Ruxpin Motherboard Replacement, Arms: stap 4, afbeelding 1 van 3 Teddy Ruxpin Motherboard Replacement, Arms: stap 4, afbeelding 2 van 3 Teddy Ruxpin Motherboard Replacement, Arms: stap 4, afbeelding 3 van 3
      • Cut the orange shirt and zip tie.
      • Remove the zip tie.
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Motherboard Replacement: stap 5, afbeelding 1 van 1
      • Cut across the back seam of the head of the bear along the arrow.
      • This damages the bear's exterior and will require resewing.
      Vraag FixBot
      Voeg opmerking toe
    3. Teddy Ruxpin Motherboard Replacement: stap 6, afbeelding 1 van 3 Teddy Ruxpin Motherboard Replacement: stap 6, afbeelding 2 van 3 Teddy Ruxpin Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Remove the interior of the doll.
      • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
      • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
      Vraag FixBot
      Voeg opmerking toe
    4. Teddy Ruxpin Motherboard Replacement: stap 7, afbeelding 1 van 2 Teddy Ruxpin Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Extract each arm button.
      • Pull on the stuffing of the bear and not the wire to remove the arm button.
      Vraag FixBot
      Voeg opmerking toe
    5. Teddy Ruxpin Motherboard Replacement: stap 8, afbeelding 1 van 2 Teddy Ruxpin Motherboard Replacement: stap 8, afbeelding 2 van 2
      • Pull off the rest of the outside layer of the bear.
      Vraag FixBot
      Voeg opmerking toe
    6. Teddy Ruxpin Motherboard Replacement: stap 9, afbeelding 1 van 1
      • Unplug the arms from the main body.
      Vraag FixBot
      Voeg opmerking toe
    1. Teddy Ruxpin Motherboard Replacement, Housing Cover: stap 10, afbeelding 1 van 3 Teddy Ruxpin Motherboard Replacement, Housing Cover: stap 10, afbeelding 2 van 3 Teddy Ruxpin Motherboard Replacement, Housing Cover: stap 10, afbeelding 3 van 3
      • Unscrew the eleven circled 12.5mm Phillips #1 screws.
      • Remove the top of the housing to access the electronics inside.
      Vraag FixBot
      Voeg opmerking toe
    1. Teddy Ruxpin Motherboard Replacement, Eyes: stap 11, afbeelding 1 van 1
      • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Motherboard Replacement: stap 12, afbeelding 1 van 2 Teddy Ruxpin Motherboard Replacement: stap 12, afbeelding 2 van 2
      • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
      Vraag FixBot
      Voeg opmerking toe
    3. Teddy Ruxpin Motherboard Replacement: stap 13, afbeelding 1 van 1
      • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Teddy Ruxpin Motherboard Replacement, Mouth: stap 14, afbeelding 1 van 2 Teddy Ruxpin Motherboard Replacement, Mouth: stap 14, afbeelding 2 van 2
      • Remove five 12.5mm Phillips #1 screws.
      • Pull the mouth mechanism out of the shell.
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Motherboard Replacement: stap 15, afbeelding 1 van 2 Teddy Ruxpin Motherboard Replacement: stap 15, afbeelding 2 van 2
      • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
      • Open the mouth mechanism
      Vraag FixBot
      Voeg opmerking toe
    1. Teddy Ruxpin Motherboard Replacement, Motherboard: stap 16, afbeelding 1 van 1
      • Remove the two 12.5 MM Phillips #1 screws holding the main motherboard into place.
      Vraag FixBot
      Voeg opmerking toe
    2. Teddy Ruxpin Motherboard Replacement: stap 17, afbeelding 1 van 1
      • Desolder all connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jayin Patel
406 Reputatie
4 handleidingen geschreven
Cal Poly, Team S18-G5, White Winter 2020 Lid van Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 2,227
