Ga door naar hoofdinhoud
Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement
Wat je nodig hebt
  1. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: stap 1, afbeelding 1 van 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: stap 1, afbeelding 2 van 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Case: stap 1, afbeelding 3 van 3
    • Use the Phillips #0 to remove the screw located on the back of the camera above the mount.
    • Slide the mount out from the bottom of the device.
  2. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: stap 2, afbeelding 1 van 1
    • Remove the back of the case by placing a iFixit opening tool underneath the edge of the case and prying it up.
  3. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the back of the case without pulling the cables connected to the motherboard and the speaker on the back of the case.
  4. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: stap 4, afbeelding 1 van 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: stap 4, afbeelding 2 van 3 Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement, Motion Sensor: stap 4, afbeelding 3 van 3
    • Facing the inside of the front of the case, release the white ribbon cable by pulling the black rectangular connector at the end of the connection
    • Once the black holder is opened, gently pull the cable out of the holder.
  5. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: stap 5, afbeelding 1 van 1
    • Facing the back of the small board, remove the two 2.0 mm Phillips #0 black screws that connect it to the back of the case.
  6. Swann Wi-Fi Indoor Security Camera Motion Sensor Replacement: stap 6, afbeelding 1 van 1
    • Carefully use a soldering iron to melt the solder in three places that connect the motion sensor. For more information on soldering follow this helpful guide.
    • Pull the sensor out from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Logan Sluder
544 Reputatie
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 597
