Inleiding
Use this guide to remove the thumbsticks in your SteelSeries Nimbus+ controller.
Wat je nodig hebt
Use your fingers to remove the phone mount by pulling it straight out of the controller.
Use your fingers to remove the sticker located on the back cover of the Nimbus+.
Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
Repair didn’t go as planned? Check our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
how can we find a replacement board with the thumbsticks?
I wonder the same thing
Bizkot -
