Ga door naar hoofdinhoud
Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement
Wat je nodig hebt
    1. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: stap 1, afbeelding 1 van 2 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: stap 1, afbeelding 2 van 2
      • Remove the six silver 11.4 mm Phillips #0 screws
      • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
      Vraag FixBot
      Voeg opmerking toe
    2. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Styrofoam Pad: stap 2, afbeelding 1 van 1
      • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
      • Do this carefully to avoid tearing the pad.
      Vraag FixBot
      Voeg opmerking toe
    3. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: stap 3, afbeelding 1 van 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: stap 3, afbeelding 2 van 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: stap 3, afbeelding 3 van 3
      • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    4. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: stap 4, afbeelding 1 van 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: stap 4, afbeelding 2 van 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: stap 4, afbeelding 3 van 3
      • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
      • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
      Vraag FixBot
      Voeg opmerking toe
    5. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Un-Soldering the Wires: stap 5, afbeelding 1 van 1
      • On the back side of the reader there are nine wires. Un-solder these wires, remove the micro SD card reader, and solder on the replacement.
      • Need Help Soldering? Check out Hoe moet je (de-)solderen? for tips.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Andrew Gittens
143 Reputatie
4 handleidingen geschreven
USF Tampa, Team 4-5, Brown Fall 2014 Lid van USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Leden
42 handleidingen geschreven
1Gids Commentaar
Where do you get the replacement parts?
clsutliff - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 814
