Ga door naar hoofdinhoud
Sony a7 Motherboard Replacement
Wat je nodig hebt
    1. Sony a7 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Flip the camera upside down, and observe where the battery door and switch are located on the camera.
      • This replacement guide is using a cardboard and tape placeholder to simulate the battery, battery door, and switch.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony a7 Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Slide the switch over to the right side to open the battery door.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony a7 Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Depress the blue lever to allow the battery to pop out slightly.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony a7 Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Remove the battery from the camera.
      • Make sure to hold onto the battery firmly when removing it from the camera, as it could slide out and fall.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony a7 Motherboard Replacement, Rear Disassembly: stap 5, afbeelding 1 van 1
      • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
      • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony a7 Motherboard Replacement: stap 6, afbeelding 1 van 3 Sony a7 Motherboard Replacement: stap 6, afbeelding 2 van 3 Sony a7 Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony a7 Motherboard Replacement: stap 7, afbeelding 1 van 1
      • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony a7 Motherboard Replacement: stap 8, afbeelding 1 van 2 Sony a7 Motherboard Replacement: stap 8, afbeelding 2 van 2
      • Remove the four M 1.5x2mm screws.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony a7 Motherboard Replacement: stap 9, afbeelding 1 van 3 Sony a7 Motherboard Replacement: stap 9, afbeelding 2 van 3 Sony a7 Motherboard Replacement: stap 9, afbeelding 3 van 3
      • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony a7 Motherboard Replacement: stap 10, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using the blunt tweezers, remove the blue ribbon cable.
      • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony a7 Motherboard Replacement: stap 11, afbeelding 1 van 2 Sony a7 Motherboard Replacement: stap 11, afbeelding 2 van 2
      • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony a7 Motherboard Replacement: stap 12, afbeelding 1 van 3 Sony a7 Motherboard Replacement: stap 12, afbeelding 2 van 3 Sony a7 Motherboard Replacement: stap 12, afbeelding 3 van 3
      • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    9. Sony a7 Motherboard Replacement: stap 13, afbeelding 1 van 1
      • Lift the metal plate and LCD screen away from the camera body.
      Vraag FixBot
      Voeg opmerking toe
    10. Sony a7 Motherboard Replacement: stap 14, afbeelding 1 van 1
      • Detach the amber ribbon cable from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony a7 Motherboard Replacement, Motherboard: stap 15, afbeelding 1 van 2 Sony a7 Motherboard Replacement, Motherboard: stap 15, afbeelding 2 van 2
      • Peel off the small adhesive tape located on the top right side of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony a7 Motherboard Replacement: stap 16, afbeelding 1 van 2 Sony a7 Motherboard Replacement: stap 16, afbeelding 2 van 2
      • Remove the exposed ribbon cable by using the iFixit opening tools
      Vraag FixBot
      Voeg opmerking toe
    3. Sony a7 Motherboard Replacement: stap 17, afbeelding 1 van 1
      • Peel off the large black protective adhesive from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony a7 Motherboard Replacement: stap 18, afbeelding 1 van 2 Sony a7 Motherboard Replacement: stap 18, afbeelding 2 van 2
      • Remove the four visible ribbon cables by using the spudger.
      • Removing the ribbon cables will require lifting a lever located on the connecter in order to pull out the cable.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony a7 Motherboard Replacement: stap 19, afbeelding 1 van 3 Sony a7 Motherboard Replacement: stap 19, afbeelding 2 van 3 Sony a7 Motherboard Replacement: stap 19, afbeelding 3 van 3
      • Remove the one U.FL plug by using the spudger.
      • Using the spudger, remove the four remaining ribbon cables.
      • These ribbon cables do not have the requirement to lift a lever on the connector as specified in previous steps.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony a7 Motherboard Replacement: stap 20, afbeelding 1 van 1
      • Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
      • Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony a7 Motherboard Replacement: stap 21, afbeelding 1 van 3 Sony a7 Motherboard Replacement: stap 21, afbeelding 2 van 3 Sony a7 Motherboard Replacement: stap 21, afbeelding 3 van 3
      • Lift the motherboard from the camera body.
      • It helps to pick up the right side of the board first, and then work sequentially down the board. Be sure to gently ease the motherboard from its clips down the remainder of the side.
      • Exercise extreme caution when removing the motherboard as it can be fragile, and damage to it could mean the camera will become unrecoverable.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony a7 Motherboard Replacement: stap 22, afbeelding 1 van 1
      • Remove the two visible ribbon cables by using the forceps.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
For SD card replacement:
Follow above guide to step 18. Remove the bottom right flex cable. There will be a hole under the cable to access a screw in the battery compartment, which holds on the grip. Remove the screw. Remove the one remaining screw in the corner of the battery compartment. The grip should now come loose. Remove the grip. Remove the two screws holding the SD card board on. Disconnect the small two wire cable from the top of the board. The board should now slide out. Disconnect the flex cable from the old board and connect to the new board for reinstall.
I did this for a Sony A7S and all is working well.
Sam Hudson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 134
Altijd: 11,600
