Ga door naar hoofdinhoud
Sony SRS-XB43 LED Module Replacement
Wat je nodig hebt
    1. Sony SRS-XB43 LED Module Replacement, Faceplate: stap 1, afbeelding 1 van 2 Sony SRS-XB43 LED Module Replacement, Faceplate: stap 1, afbeelding 2 van 2
      • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
      • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
      • Fully open the hinged mesh cover and pry it off the unit.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony SRS-XB43 LED Module Replacement: stap 2, afbeelding 1 van 1
      • Turn the speaker so the back is facing you.
      • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
      • Remove the single screw using a T8 Torx.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony SRS-XB43 LED Module Replacement: stap 3, afbeelding 1 van 1
      • Remove all ten screws using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony SRS-XB43 LED Module Replacement: stap 4, afbeelding 1 van 2 Sony SRS-XB43 LED Module Replacement: stap 4, afbeelding 2 van 2
      • Slowly lift the speaker face off of the housing unit.
      • Unplug the six wires connecting the faceplate to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony SRS-XB43 LED Module Replacement, Battery: stap 5, afbeelding 1 van 2 Sony SRS-XB43 LED Module Replacement, Battery: stap 5, afbeelding 2 van 2
      • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
      • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
      • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony SRS-XB43 LED Module Replacement: stap 6, afbeelding 1 van 3 Sony SRS-XB43 LED Module Replacement: stap 6, afbeelding 2 van 3 Sony SRS-XB43 LED Module Replacement: stap 6, afbeelding 3 van 3
      • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
      • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony SRS-XB43 LED Module Replacement: stap 7, afbeelding 1 van 2 Sony SRS-XB43 LED Module Replacement: stap 7, afbeelding 2 van 2
      • Orient the plastic chassis so that the port housing PCB is facing upward.
      • Remove the plastic black film covering the battery, leaving the blue battery exposed.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony SRS-XB43 LED Module Replacement: stap 8, afbeelding 1 van 2 Sony SRS-XB43 LED Module Replacement: stap 8, afbeelding 2 van 2
      • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
      • Using your fingers, pull upwards until the battery is removed from its enclosure.
      • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony SRS-XB43 LED Module Replacement, LED Module: stap 9, afbeelding 1 van 1
      • Orient the motherboard chassis so that the battery compartment is facing upwards.
      • Identify the two LED control PCBs located on the left and right edges of the plastic chassis.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony SRS-XB43 LED Module Replacement: stap 10, afbeelding 1 van 3 Sony SRS-XB43 LED Module Replacement: stap 10, afbeelding 2 van 3 Sony SRS-XB43 LED Module Replacement: stap 10, afbeelding 3 van 3
      • Identify the black latch on each of the plugs that are connected to the PBCs.
      • Swing the black latch open by gently prying the front/extruding lip of the plug with a spudger or other flat tool.
      • To give a sense of direction, the latch should swing away from you or towards the LED (metallic square).
      • Grab each ribbon cable and apply a horizontal pulling force (with respect to the LED control PCBs) to disconnect them from the connectors.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony SRS-XB43 LED Module Replacement: stap 11, afbeelding 1 van 3 Sony SRS-XB43 LED Module Replacement: stap 11, afbeelding 2 van 3 Sony SRS-XB43 LED Module Replacement: stap 11, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Insert the spudger below the LED control PCBs and pry to remove it from the plastic chassis.
      • The PCBs are held onto the chassis with a considerably strong double-sided tape. If the spudger is too thick and can not fit under the PCBs, use a thin plastic pick or plastic card.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Isaac Oliveira
282 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Leden
10 handleidingen geschreven
1Gids Commentaar
i need email to contact You please
Danny Bryan Vega - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 972
