Ga door naar hoofdinhoud
Sony RM-LVR1 Motherboard Replacement
Wat je nodig hebt
    1. Sony RM-LVR1 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
      • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony RM-LVR1 Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Battery is the rectangular and silver object in the center of device.
      • Remove battery with finger by prying at the rear.
      • If unable to remove battery, pry out using spudger.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony RM-LVR1 Motherboard Replacement, LCD Screen: stap 3, afbeelding 1 van 2 Sony RM-LVR1 Motherboard Replacement, LCD Screen: stap 3, afbeelding 2 van 2
      • Unscrew the 3 (three) screws holding the bracket in place.
      • Then remove the bracket by prying one end up.
      • Do not rip the ribbon cable connecting the bracket to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony RM-LVR1 Motherboard Replacement: stap 4, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • With tweezers, unplug the ribbon cable from the white connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony RM-LVR1 Motherboard Replacement: stap 5, afbeelding 1 van 1
      • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony RM-LVR1 Motherboard Replacement: stap 6, afbeelding 1 van 1
      • Gently push out on these two clips holding the LCD to the motherboard
      • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
      • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
      Vraag FixBot
      Voeg opmerking toe
    5. Sony RM-LVR1 Motherboard Replacement: stap 7, afbeelding 1 van 2 Sony RM-LVR1 Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
      Vraag FixBot
      Voeg opmerking toe
    6. Sony RM-LVR1 Motherboard Replacement: stap 8, afbeelding 1 van 1
      • Remove the screen from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 678
