Ga door naar hoofdinhoud
Sony NEX-7 SD card Replacement
    1. Sony NEX-7 SD card Replacement, Battery: stap 1, afbeelding 1 van 2 Sony NEX-7 SD card Replacement, Battery: stap 1, afbeelding 2 van 2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony NEX-7 SD card Replacement: stap 2, afbeelding 1 van 1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony NEX-7 SD card Replacement: stap 3, afbeelding 1 van 1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony NEX-7 SD card Replacement, SD card: stap 4, afbeelding 1 van 1
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To replace the SD card, press the card into the slot until it clicks. It will stay on its own. If it doesn't go in all the way, make sure the gold contacts are down and towards the battery door.
Jay Miley
5.462 Reputatie
13 handleidingen geschreven
Cal Poly, Team 10-55, Amido Spring 2014 Lid van Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Leden
65 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 56
Altijd: 2,630
