Ga door naar hoofdinhoud
Sony NEX-7 Lens Mount Replacement
Wat je nodig hebt
    1. Sony NEX-7 Lens Mount Replacement, Battery: stap 1, afbeelding 1 van 2 Sony NEX-7 Lens Mount Replacement, Battery: stap 1, afbeelding 2 van 2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony NEX-7 Lens Mount Replacement: stap 2, afbeelding 1 van 1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony NEX-7 Lens Mount Replacement: stap 3, afbeelding 1 van 1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony NEX-7 Lens Mount Replacement, SD card: stap 4, afbeelding 1 van 1
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony NEX-7 Lens Mount Replacement, Lens: stap 5, afbeelding 1 van 2 Sony NEX-7 Lens Mount Replacement, Lens: stap 5, afbeelding 2 van 2
      • First, turn the camera upside down.
      • Press the button located next to silver lens mount and rotate the lens counterclockwise.
      • Pull the lens away from the camera body.
      • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony NEX-7 Lens Mount Replacement, Lens Mount: stap 6, afbeelding 1 van 1
      • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony NEX-7 Lens Mount Replacement: stap 7, afbeelding 1 van 1
      • Remove these three layers from the lens mount with your finger or by turning the camera face down.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony NEX-7 Lens Mount Replacement: stap 8, afbeelding 1 van 1
      • Remove the two newly visible #00 screws within the metal ring.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony NEX-7 Lens Mount Replacement: stap 9, afbeelding 1 van 1
      • Remove the final metal ring from the mount.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jay Miley
5.462 Reputatie
13 handleidingen geschreven
Cal Poly, Team 10-55, Amido Spring 2014 Lid van Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Leden
65 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 43
Altijd: 3,040
