Ga door naar hoofdinhoud
Sony Handycam FDR-AX33 Microphone Replacement
Wat je nodig hebt
    1. Sony Handycam FDR-AX33 Microphone Replacement, Panel: stap 1, afbeelding 1 van 2 Sony Handycam FDR-AX33 Microphone Replacement, Panel: stap 1, afbeelding 2 van 2
      • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
      • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
      • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
      • Be sure to un-velcro the handle strap.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Handycam FDR-AX33 Microphone Replacement: stap 2, afbeelding 1 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 2, afbeelding 2 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 2, afbeelding 3 van 3
      • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
      • Remove the 4 mm Phillips #00 screw from the right panel.
      • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
      • You may have to use the opening tool to remove this panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Handycam FDR-AX33 Microphone Replacement: stap 3, afbeelding 1 van 2 Sony Handycam FDR-AX33 Microphone Replacement: stap 3, afbeelding 2 van 2
      • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
      • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony Handycam FDR-AX33 Microphone Replacement: stap 4, afbeelding 1 van 2 Sony Handycam FDR-AX33 Microphone Replacement: stap 4, afbeelding 2 van 2
      • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
      • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony Handycam FDR-AX33 Microphone Replacement: stap 5, afbeelding 1 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 5, afbeelding 2 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 5, afbeelding 3 van 3
      • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
      • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
      • Pull the top panel off of the device with the iFixit opening tool.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony Handycam FDR-AX33 Microphone Replacement: stap 6, afbeelding 1 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 6, afbeelding 2 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 6, afbeelding 3 van 3
      • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
      • Use the iFixit opening tool to remove the screen hinge.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony Handycam FDR-AX33 Microphone Replacement: stap 7, afbeelding 1 van 2 Sony Handycam FDR-AX33 Microphone Replacement: stap 7, afbeelding 2 van 2
      • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
      • Angle the eyepiece up to reach the screw with the screwdriver.
      • Take the panel directly to the right of the battery slot off of the camera.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony Handycam FDR-AX33 Microphone Replacement: stap 8, afbeelding 1 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 8, afbeelding 2 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 8, afbeelding 3 van 3
      • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
      • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
      • Wiggle the left panel and pull it out gently.
      • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony Handycam FDR-AX33 Microphone Replacement, Microphone: stap 9, afbeelding 1 van 1
      • Pry up the plastic frame around the camera’s microphone.
      • Be careful with the thin plastic frame as it might break. If it does break, it shouldn't affect the camera's performance.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony Handycam FDR-AX33 Microphone Replacement: stap 10, afbeelding 1 van 1
      • Pull back clips to release microphone.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony Handycam FDR-AX33 Microphone Replacement: stap 11, afbeelding 1 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 11, afbeelding 2 van 3 Sony Handycam FDR-AX33 Microphone Replacement: stap 11, afbeelding 3 van 3
      • Desolder the three connections on the bottom of the microphone. Refer to the soldering guide linked here.
      • Remove the two 3 mm Phillips #00 screws to release the microphone mount.
      • Removing the microphone mount is not required to replace the microphone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cameron Casey
187 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G2, White Winter 2019 Lid van Cal Poly, Team S18-G2, White Winter 2019
CPSU-WHITE-W19S18G2
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 29
Altijd: 1,049
