Ga door naar hoofdinhoud
Sony DualSense Controller L1 and R1 Button Replacement
Wat je nodig hebt
  1. Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: stap 1, afbeelding 1 van 3 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: stap 1, afbeelding 2 van 3 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: stap 1, afbeelding 3 van 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  2. Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: stap 2, afbeelding 1 van 3 Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: stap 2, afbeelding 2 van 3 Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: stap 2, afbeelding 3 van 3
    • Repeat the previous step to remove the R1 button.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Sam Omiotek
83.765 Reputatie
290 handleidingen geschreven
3 opmerkingen
It is easier to remove L1/R1 by going from below than by from above- without any damages.
Grim Of Doom - Antwoord
Does the spudger dent or mark the button when doing this?
Rory Bedell - Antwoord
My replacement R1 button is different enough to not fit. Fins around center sleeve are wider. So there must have been a design change at some point.
Walt Mather - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 48
Afgelopen 7 dagen: 307
Afgelopen 30 dagen: 1,116
Altijd: 31,220
