Ga door naar hoofdinhoud
Sony DualSense Controller Front Case Replacement
Wat je nodig hebt
    1. Sony DualSense Controller Front Case Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 2 van 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 3 van 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 2 van 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 3 van 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony DualSense Controller Front Case Replacement, Remove the middle trim: stap 5, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Remove the middle trim: stap 5, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Remove the middle trim: stap 5, afbeelding 3 van 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the L1 button: stap 6, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Remove the L1 button: stap 6, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Remove the L1 button: stap 6, afbeelding 3 van 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement, Remove the R1 button: stap 7, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Remove the R1 button: stap 7, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Remove the R1 button: stap 7, afbeelding 3 van 3
      • Repeat the previous step to remove the R1 button.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the rear case screws: stap 8, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the rear case screws: stap 8, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement: stap 9, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 9, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement, Separate the rear case: stap 10, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Separate the rear case: stap 10, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Separate the rear case: stap 10, afbeelding 3 van 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony DualSense Controller Front Case Replacement: stap 11, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement: stap 11, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement: stap 11, afbeelding 3 van 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony DualSense Controller Front Case Replacement: stap 12, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement: stap 12, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement: stap 12, afbeelding 3 van 3
      • Repeat the previous step on the right edge to release its clips.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony DualSense Controller Front Case Replacement: stap 13, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 13, afbeelding 2 van 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the rear case: stap 14, afbeelding 1 van 1
      • Remove the rear case.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Disconnect the battery: stap 15, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Disconnect the battery: stap 15, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Grip the connector, not the wires, when disconnecting.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement, Remove the battery: stap 16, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the battery: stap 16, afbeelding 2 van 2
      • Lift the battery straight out of the battery bracket.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the lower microphone: stap 17, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the lower microphone: stap 17, afbeelding 2 van 2
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement, Remove the battery bracket: stap 18, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the battery bracket: stap 18, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement: stap 19, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 19, afbeelding 2 van 2
      • Lift the battery bracket out of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony DualSense Controller Front Case Replacement, Disconnect the right trigger assembly: stap 20, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Disconnect the right trigger assembly: stap 20, afbeelding 2 van 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      • Do not completely remove the ribbon cable yet.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony DualSense Controller Front Case Replacement: stap 21, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 21, afbeelding 2 van 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      • Remove the ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony DualSense Controller Front Case Replacement, Disconnect the left trigger assembly: stap 22, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Disconnect the left trigger assembly: stap 22, afbeelding 2 van 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony DualSense Controller Front Case Replacement: stap 23, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 23, afbeelding 2 van 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      Vraag FixBot
      Voeg opmerking toe
    8. Sony DualSense Controller Front Case Replacement, Disconnect the upper microphone: stap 24, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Disconnect the upper microphone: stap 24, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    9. Sony DualSense Controller Front Case Replacement, Disconnect the touchpad: stap 25, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Disconnect the touchpad: stap 25, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
      Vraag FixBot
      Voeg opmerking toe
    10. Sony DualSense Controller Front Case Replacement, Lift out the motherboard: stap 26, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Lift out the motherboard: stap 26, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Lift out the motherboard: stap 26, afbeelding 3 van 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
      • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the light guide: stap 27, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the light guide: stap 27, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement: stap 28, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 28, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to remove the light guide bracket.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement: stap 29, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 29, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to remove the light guide.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the speaker: stap 30, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Remove the speaker: stap 30, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Remove the speaker: stap 30, afbeelding 3 van 3
      • Use a pair of tweezers to remove the speaker from the midframe.
      • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement, Remove the midframe: stap 31, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the midframe: stap 31, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement: stap 32, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement: stap 32, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement: stap 32, afbeelding 3 van 3
      • Carefully lift the midframe and motherboard up and out of the front case.
      • Be careful not to strain the vibrator motor wires.
      • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the touchpad: stap 33, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the touchpad: stap 33, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the touchpad bracket to the touchpad.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement: stap 34, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement: stap 34, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement: stap 34, afbeelding 3 van 3
      • Lift the touchpad bracket straight up off the front case.
      • Feed the ribbon cable back through the rectangular slot in the bracket during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement: stap 35, afbeelding 1 van 1
      • Lift the front case up off of the touchpad.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: stap 36, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: stap 36, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: stap 36, afbeelding 3 van 3
      • Use a pair of tweezers or your fingers to remove the three conductive silicone rubber pads from the inside of the front case.
      • The buttons are resting loose in the front case.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DualSense Controller Front Case Replacement, Remove the buttons: stap 37, afbeelding 1 van 1
      • Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DualSense Controller Front Case Replacement, Remove the touchpad bezel: stap 38, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the touchpad bezel: stap 38, afbeelding 2 van 2
      • Use your fingers to remove the touchpad bezel from the front case.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony DualSense Controller Front Case Replacement: stap 39, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement: stap 39, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to remove the rubber insulation pad from the front case.
      Vraag FixBot
      Voeg opmerking toe
    5. Sony DualSense Controller Front Case Replacement, Remove the upper microphone: stap 40, afbeelding 1 van 2 Sony DualSense Controller Front Case Replacement, Remove the upper microphone: stap 40, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to remove the upper microphone from the front case.
      • Feed the microphone ribbon cable out carefully—the pull tab may catch on the front case.
      Vraag FixBot
      Voeg opmerking toe
    6. Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: stap 41, afbeelding 1 van 3 Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: stap 41, afbeelding 2 van 3 Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: stap 41, afbeelding 3 van 3
      • Use your fingers to lightly pinch the plastic clip securing the microphone mute button to the front case and remove it.
      Vraag FixBot
      Voeg opmerking toe
    7. Sony DualSense Controller Front Case Replacement: stap 42, afbeelding 1 van 1
      • Only the front case remains.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
23 andere personen hebben deze handleiding voltooid.
Sam Omiotek
99.986 Reputatie
289 handleidingen geschreven
2Gids Commentaar
need an update for the “a” variant (cfi-zct1w a)
this guide works for it up until a point (the touchpad), the a variant only has 1 screw instead of two and i couldn’t get the touchpad itself removed from it’s bracket (steps 30/31)
also the “a” variant is missing the light guide bracket (step 25)
name nameson - Antwoord Deel
Two broken controllers became a working one. I had a small discrepancy with touchpad but figured it out. Thanks for the guide.
Dmytro Y. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 366
Afgelopen 30 dagen: 1,565
Altijd: 51,645
