Ga door naar hoofdinhoud
Sony DVP-SR200P Power Supply Circuit Board Replacement
Wat je nodig hebt
  1. Sony DVP-SR200P Power Supply Circuit Board Replacement, Top Cover: stap 1, afbeelding 1 van 2 Sony DVP-SR200P Power Supply Circuit Board Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 2, afbeelding 1 van 2 Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Power Supply Circuit Board Replacement, Processing Board: stap 3, afbeelding 1 van 1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 4, afbeelding 1 van 2 Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P Power Supply Circuit Board Replacement, Power Supply Circuit Board: stap 7, afbeelding 1 van 1
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Unhook the power supply connector from the power supply board by pressing down on the small latch.
  8. Sony DVP-SR200P Power Supply Circuit Board Replacement: stap 8, afbeelding 1 van 1
    • Orient the DVD player so the back of the DVD player is opposite of you.
    • Unscrew the two silver 4.8 mm Phillips #1 screws that attach the power supply circuit board to the bottom of the DVD player.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brian Hua
80 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-17, Forte Winter 2013 Lid van Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Leden
6 handleidingen geschreven
2 opmerkingen
my sony home theater showing push power protector how to resolve it.
Vinod Kumar - Antwoord
Service center said that we need to change motherboard. plz help me out if you can
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 8,541
