Ga door naar hoofdinhoud
Sony DVP-SR200P DVD Drive Replacement
Wat je nodig hebt
    1. Sony DVP-SR200P DVD Drive Replacement, Top Cover: stap 1, afbeelding 1 van 2 Sony DVP-SR200P DVD Drive Replacement, Top Cover: stap 1, afbeelding 2 van 2
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DVP-SR200P DVD Drive Replacement: stap 2, afbeelding 1 van 2 Sony DVP-SR200P DVD Drive Replacement: stap 2, afbeelding 2 van 2
      • Slide the cover away from the front of the DVD player until it is off.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DVP-SR200P DVD Drive Replacement, Processing Board: stap 3, afbeelding 1 van 1
      • Remove the blue tape from the processing board by gently pulling upward.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DVP-SR200P DVD Drive Replacement: stap 4, afbeelding 1 van 2 Sony DVP-SR200P DVD Drive Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      Vraag FixBot
      Voeg opmerking toe
    3. Sony DVP-SR200P DVD Drive Replacement: stap 5, afbeelding 1 van 1
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      Vraag FixBot
      Voeg opmerking toe
    4. Sony DVP-SR200P DVD Drive Replacement: stap 6, afbeelding 1 van 1
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      Vraag FixBot
      Voeg opmerking toe
    1. Sony DVP-SR200P DVD Drive Replacement, DVD Drive: stap 7, afbeelding 1 van 1
      • Orient the DVD player so the front of the DVD player is opposite of you.
      • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
      Vraag FixBot
      Voeg opmerking toe
    2. Sony DVP-SR200P DVD Drive Replacement: stap 8, afbeelding 1 van 1
      • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kaitlyn Reilly
54 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-17, Forte Winter 2013 Lid van Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Leden
72 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 86
Altijd: 4,680
