Ga door naar hoofdinhoud
Sonos Roam Outer Circuit Board Replacement
Wat je nodig hebt
  1. Sonos Roam Outer Circuit Board Replacement, End Caps: stap 1, afbeelding 1 van 3 Sonos Roam Outer Circuit Board Replacement, End Caps: stap 1, afbeelding 2 van 3 Sonos Roam Outer Circuit Board Replacement, End Caps: stap 1, afbeelding 3 van 3
    • Power off your Sonos Roam before beginning disassembly.
    • Use the metal spudger to pry the end cap with the buttons.
    • Pry from all sides to loosen the adhesive.
    • Use the iOpener, a blowdryer, or a similar heating device to loosen the adhesive if having difficulty.
  2. Sonos Roam Outer Circuit Board Replacement: stap 2, afbeelding 1 van 2 Sonos Roam Outer Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Flip the device to the other end cap.
    • Use the metal spudger to loosen the adhesive.
  3. Sonos Roam Outer Circuit Board Replacement, Speaker Grille: stap 3, afbeelding 1 van 2 Sonos Roam Outer Circuit Board Replacement, Speaker Grille: stap 3, afbeelding 2 van 2
    • Flip the device so that the Sonos logo is on the top.
    • Use the Torx T6 screwdriver to remove the two 6 mm screws.
  4. Sonos Roam Outer Circuit Board Replacement: stap 4, afbeelding 1 van 2 Sonos Roam Outer Circuit Board Replacement: stap 4, afbeelding 2 van 2
    • Flip the device.
  5. Sonos Roam Outer Circuit Board Replacement: stap 5, afbeelding 1 van 3 Sonos Roam Outer Circuit Board Replacement: stap 5, afbeelding 2 van 3 Sonos Roam Outer Circuit Board Replacement: stap 5, afbeelding 3 van 3
    • Flip the device so the Sonos logo is on the top.
    • Use the iFixit opening picks to wedge between the split of the grille and the back of the speaker to pry the grille apart.
  6. Sonos Roam Outer Circuit Board Replacement, Speaker Module: stap 6, afbeelding 1 van 2 Sonos Roam Outer Circuit Board Replacement, Speaker Module: stap 6, afbeelding 2 van 2
    • Use the TR10 Torx screwdriver to remove the six 7 mm screws.
  7. Sonos Roam Outer Circuit Board Replacement: stap 7, afbeelding 1 van 3 Sonos Roam Outer Circuit Board Replacement: stap 7, afbeelding 2 van 3 Sonos Roam Outer Circuit Board Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Begin to carefully separate the speaker module from the device.
    • Firmly squeeze the middle of the plug using the tweezers to pull it out of the socket.
    • Separate the speaker module from the device.
  8. Sonos Roam Outer Circuit Board Replacement, Outer Circuit Board: stap 8, afbeelding 1 van 2 Sonos Roam Outer Circuit Board Replacement, Outer Circuit Board: stap 8, afbeelding 2 van 2
    • Use the TR10 Torx screwdriver to remove the four 7 mm screws.
  9. Sonos Roam Outer Circuit Board Replacement: stap 9, afbeelding 1 van 3 Sonos Roam Outer Circuit Board Replacement: stap 9, afbeelding 2 van 3 Sonos Roam Outer Circuit Board Replacement: stap 9, afbeelding 3 van 3
    Koop
    • Use the tweezers to flip the latch holding the large ribbon in place.
    • Grab the large ribbon with the tweezers and pull upwards to remove it.
    • Use the tweezers to flip the latch holding the small ribbon in place.
    • Grab the small ribbon with the tweezers and pull upwards to remove it.
  10. Sonos Roam Outer Circuit Board Replacement: stap 10, afbeelding 1 van 3 Sonos Roam Outer Circuit Board Replacement: stap 10, afbeelding 2 van 3 Sonos Roam Outer Circuit Board Replacement: stap 10, afbeelding 3 van 3
    • Grab the metal piece sticking out of the outer circuit board.
    • Pull upwards to remove the outer circuit board.
  11. Sonos Roam Outer Circuit Board Replacement: stap 11, afbeelding 1 van 2 Sonos Roam Outer Circuit Board Replacement: stap 11, afbeelding 2 van 2
    • Soldering Iron is very hot and can cause injury if not used properly.
    • Use a soldering iron to desolder the outer circuit board from the speaker casing.
Conclusie
Lauren Young
614 Reputatie
5 handleidingen geschreven
Utah Tech University, Team 1-2, McMurrin Fall 2023 Lid van Utah Tech University, Team 1-2, McMurrin Fall 2023
UTAHTECH-MCMURRIN-F23S1G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 185
