Ga door naar hoofdinhoud
Solio Rocsta LED Replacement
Wat je nodig hebt
  1. Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: stap 1, afbeelding 1 van 2 Solio Rocsta LED Replacement, Solio Rocsta Top Cover Disassembly: stap 1, afbeelding 2 van 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Solio Rocsta LED Replacement: stap 2, afbeelding 1 van 2 Solio Rocsta LED Replacement: stap 2, afbeelding 2 van 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
    Vraag FixBot
    Voeg opmerking toe
  3. Solio Rocsta LED Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the spudger, pry the battery off the back cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Solio Rocsta LED Replacement: stap 4, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case and flip the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  5. Solio Rocsta LED Replacement: stap 5, afbeelding 1 van 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
    Vraag FixBot
    Voeg opmerking toe
  6. Solio Rocsta LED Replacement, LED: stap 6, afbeelding 1 van 1
    • Using a T6 Torx screwdriver, unscrew the 5.66 mm screws attaching the circuit board to the case.
    Vraag FixBot
    Voeg opmerking toe
  7. Solio Rocsta LED Replacement: stap 7, afbeelding 1 van 1
    • Flip the circuit board to be able to see where the LEDs are soldered to.
    • With a Soldering Iron, desolder the LEDs’ connectors.
    • For more information on how to solder and desolder connections, please visit this guide.
    Vraag FixBot
    Voeg opmerking toe
  8. Solio Rocsta LED Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Gently pry the LEDs using one of the Precision Tweezers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Vazquez
577 Reputatie
5 handleidingen geschreven
USF Tampa, Team S13-G13, Cagle Fall 2017 Lid van USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 364
