Inleiding
The USB port allows you to connect other devices for charging. The replacement of the USB port requires soldering and if not done properly can damage the device. Guides for how to solder and desolder can be found on iFixit's website. Hoe moet je (de-)solderen?
Wat je nodig hebt
Turn off the device by pressing on the clear power button behind the device.
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
Remove solder from both spots on outside of the USB port.
Remove solder from base of the USB port.
