Ga door naar hoofdinhoud
Skullcandy Crusher Wireless Bluetooth Antenna Replacement
Wat je nodig hebt
  1. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: stap 1, afbeelding 1 van 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Ear Cushion: stap 1, afbeelding 2 van 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 2, afbeelding 1 van 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 2, afbeelding 2 van 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 3, afbeelding 1 van 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: stap 4, afbeelding 1 van 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement, Bluetooth Antenna: stap 4, afbeelding 2 van 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
  5. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 5, afbeelding 1 van 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 5, afbeelding 2 van 3 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 5, afbeelding 3 van 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker assembly away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 6, afbeelding 1 van 2 Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 6, afbeelding 2 van 2
    • Separate headphone speaker assembly from headphone speaker frame.
  7. Skullcandy Crusher Wireless Bluetooth Antenna Replacement: stap 7, afbeelding 1 van 1
    • The Bluetooth antenna module chip is located on the right top corner of the motherboard.
    • If necessary, the chip module can be desoldered and replaced with a new one. Or, the motherboard can be replaced.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Val
1.080 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Lid van UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 Lid
12 handleidingen geschreven
Één opmerking
Where can one purchase a replacement chip?
Josh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 913
