Ga door naar hoofdinhoud
Skullcandy Crusher Wireless Battery Replacement
Wat je nodig hebt
  1. Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: stap 1, afbeelding 1 van 2 Skullcandy Crusher Wireless Battery Replacement, Ear Cushion: stap 1, afbeelding 2 van 2
    • Take your headphones and hold them upside down for better control with your hands.
  2. Skullcandy Crusher Wireless Battery Replacement: stap 2, afbeelding 1 van 2 Skullcandy Crusher Wireless Battery Replacement: stap 2, afbeelding 2 van 2
    • Grab the ear cushion firmly between your thumb and forefinger with a tight grip.
    • Pull the ear cushion away from the plastic, covering the speaker, by sliding the ear cushion down to release it.
  3. Skullcandy Crusher Wireless Battery Replacement: stap 3, afbeelding 1 van 1
    • Continue pulling it away from the edges of the plastic covering until the cushion is fully removed.
  4. Skullcandy Crusher Wireless Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Skullcandy Crusher Wireless Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove three 12 mm Phillips #1 screws located underneath the left ear cushion of the headphones.
    • You have to work on the right-side earphone.
  5. Skullcandy Crusher Wireless Battery Replacement: stap 5, afbeelding 1 van 3 Skullcandy Crusher Wireless Battery Replacement: stap 5, afbeelding 2 van 3 Skullcandy Crusher Wireless Battery Replacement: stap 5, afbeelding 3 van 3
    • Slide a plastic opening tool between the plastic frame and speaker assembly of the headphones.
    • Gently pry the speaker part away from the frame of the headphones.
  6. Skullcandy Crusher Wireless Battery Replacement: stap 6, afbeelding 1 van 2 Skullcandy Crusher Wireless Battery Replacement: stap 6, afbeelding 2 van 2
    • Separate the headphone speaker assembly from the headphone speaker frame.
  7. Skullcandy Crusher Wireless Battery Replacement: stap 7, afbeelding 1 van 3 Skullcandy Crusher Wireless Battery Replacement: stap 7, afbeelding 2 van 3 Skullcandy Crusher Wireless Battery Replacement: stap 7, afbeelding 3 van 3
    • Remove the battery from the headphone housing.
    • Use a soldering iron to desolder the black, red, and yellow cables from the board and disconnect the battery.
    • For more information on soldering, please, use this Solder and Desolder Connections guide.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Val
1.227 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Lid van UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 Lid
13 handleidingen geschreven
5Gids Commentaar
Hi, Can you specify this replacement batterys name and model number?
kituserkituserkituser kit - Antwoord Deel
1050mAh, 3,7V 3,885Wh
Mika Björn Wilhelmsen - Deel
Which battery should i buy for my skull candy hes evo??
Lakshit Meena - Antwoord Deel
donde puedo conseguir la bateria de los skullcandy crusher?
y cual bateria lleva?
pedro landeros - Antwoord Deel
Am I able to send my headphones to you to be fixed?
If I can, what would the cost be?
I have two headphone sets
Jeffrey Timothy Valerie - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 243
Altijd: 14,916
