Ga door naar hoofdinhoud
Sharper Image iPulse SI325 LED Lights Replacement
Wat je nodig hebt
    1. Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: stap 1, afbeelding 1 van 2 Sharper Image iPulse SI325 LED Lights Replacement, Outer Case: stap 1, afbeelding 2 van 2
      • Gently position the device so that the buttons and speakers lie face down.
      • Unplug the power cord from the "DC Input."
      Vraag FixBot
      Voeg opmerking toe
    2. Sharper Image iPulse SI325 LED Lights Replacement: stap 2, afbeelding 1 van 3 Sharper Image iPulse SI325 LED Lights Replacement: stap 2, afbeelding 2 van 3 Sharper Image iPulse SI325 LED Lights Replacement: stap 2, afbeelding 3 van 3
      • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
      • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
      • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
      • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
      • A small gap will open as the two tabs are released.
      • Do not pull the two halves apart yet. They are held together by the speaker wire.
      Vraag FixBot
      Voeg opmerking toe
    3. Sharper Image iPulse SI325 LED Lights Replacement: stap 3, afbeelding 1 van 2 Sharper Image iPulse SI325 LED Lights Replacement: stap 3, afbeelding 2 van 2
      • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
      • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
      • Lay the device down, so that all the internal components are facing upwards.
      Vraag FixBot
      Voeg opmerking toe
    1. Sharper Image iPulse SI325 LED Lights Replacement, Speakers: stap 4, afbeelding 1 van 2 Sharper Image iPulse SI325 LED Lights Replacement, Speakers: stap 4, afbeelding 2 van 2
      • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
      • Wiggling the connector back and forth as you pull will make removal easier.
      Vraag FixBot
      Voeg opmerking toe
    2. Sharper Image iPulse SI325 LED Lights Replacement: stap 5, afbeelding 1 van 2 Sharper Image iPulse SI325 LED Lights Replacement: stap 5, afbeelding 2 van 2
      • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
      Vraag FixBot
      Voeg opmerking toe
    1. Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: stap 6, afbeelding 1 van 2 Sharper Image iPulse SI325 LED Lights Replacement, LED Lights: stap 6, afbeelding 2 van 2
      • Remove the four 7mm Phillips #1 screws on the circuit board with the LED lights.
      • Slowly lift the circuit board out of the front cover and place the cover out of the way.
      Vraag FixBot
      Voeg opmerking toe
    2. Sharper Image iPulse SI325 LED Lights Replacement: stap 7, afbeelding 1 van 2 Sharper Image iPulse SI325 LED Lights Replacement: stap 7, afbeelding 2 van 2
      • Remove the solder connecting the LED light that needs replacement.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Melissa Pasa
701 Reputatie
7 handleidingen geschreven
Cal Poly, Team 11-33, Amido Fall 2013 Lid van Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 Leden
39 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 769
