Inleiding
The Shark ION RV754 battery powers the device so that it can move and clean. If your vacuum isn’t holding a charge or stops running early, it might be time to replace the battery. Replacement batteries can be purchased from the Shark website or 3rd-party retailers like Amazon.
Before you begin, make sure to power off your robot vacuum and it's not connected to the charging dock or a charging adaptor.
Wat je nodig hebt
Place the unit on its back with the wheels facing up.
Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
Use your finger to lift off the battery door using the small indent next to it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
